Introduction: How to Make a Model of the Ocean
I'm going to show you how to make a fast and fun model of the ocean. You can add other things if you would like too.
You will need:
1. Tinfoil
2. 4 Pieces of Blue construction paper
3. Wooden Skewer
4. Tape
5. Scissors
6. Hammer
Step 1: Making the Base
Get the four pieces of contruction paper and tape them using the tape to make a rectange. You can also use the scissors to cut the tape.
Step 2: Making the Boats
We are going to make big boats and small boats like the ones in the picture. You can make as many as you want. You can use the hammer to shape the tinfoil like I did and use the scissors to cut the tape. To make a big boat get a piece of tinfoil and shape it like the picture above or like a almond and then make the bottom and top flat. Then make a 3D rectangle using another piece of tinfoil. Finally, make 2 or 3 rectangles. Put the rectangle on the boat and tape it, then the cylinders. To make a small boat get a piece of tinfoil and make it into a cylinder then make the ends pointy. Then you use your skewer make space or the other side of a hammer so it can be a place to sit. To make a human to put inside the small boat get a piece of tinfoil and go to the very bottom of the tinfoil. Shape the tinfoil to look like legs then make the body at the top, then on the side make arms and then on the top of the body make a head.
Step 3: Make the Fish
Now we are going to make fish. You can use the scissors to cut the tape and the hammer to shape. Get a piece of tinfoil and shape it like a oval or circle. Make a small piece of tinfoil look like a boomerang or banana then tape it to then oval. Finally, use the skewer to poke eyes. To make a shark look like it is emerging from water first get a piece of tinfoil and shape it like a almond and make the bottom flat. then make three fins and stick one on top and two on the side using the tape. Poke eyes with the skewer and then make a mouth by opening the front like a bag.
Step 4: Assemble
You can tape the boats and fishes any where you want and tape it and use the scissors to cut the tape if needed or you could do it like I did in the picture.
