Introduction: How to Make a Multi-layered Plywood Dragon Craft
Laser cut multi-layered plywood dragon craft! You can create it by yourself! As for what color is completely up to you,So use your imagination to do it. You’ll get something different. Now is going to use a Thunder Laser system to make a multi-layered plywood dragon craft. Let’s start to explore fun with the laser!
Material: 3mm plywood
Other items: some glue
Laser head: standard head
Laser cutting machine: Nova35 80watt
Step 1: Setting Parameters:
Processing Mode:Cutting speed: 40mm/s
Cutting power: 70%
You can also draw on CorelDraw and then click on the laser plug-in to switch to the laser software. Set the appropriate parameters on the laser software and click Download to transfer the design to your laser cutting machine.
Step 2: Assembly Them:
Place the plywood on the work table of the Laser cutting machine, move the laser head to the proper position, adjust the focal length, press the “Origin” on the LCD control panel to set the starting position, and then press the “Start” to start the work.Collect all the pieces cut out, Let’s colour them!.
Step 3: Finished Product Display:
Now we got this colourful artwork.
