Introduction: How to Make a Multituse Concrete Cup
About: A science lover Born to create
Want an homemade pen stand, plant pot or candel stand all you need to know is down here
what you need is : big plastic cup(cup noodles),small tin can cement ,water,some stones
Step 1: Materials to Be Collected
Step 2: Mixing of Cement
The cement shall be mixed in such that for 3 parts of water there should be mixed with 4 parts of cement .It should be mixed until there are no lumps in it & have a flow consistency.
Step 3: Filling the Cup
At the first fill the cup upto 1cm to 1.5cm then keep the can inside the cup.as centered as posible then fill the space between the cup and tincan hen shake the cup to remove the air bubbles from the cement mix filled & put some weight or rocks in/on the can. The cup is set aside for 1-2 day for the cement to dry.
Step 4: Its Ready
when its all dry take an xactoknife and cut the outer cup and remove it then slowly twist up the tin can out then sand the edges. you concrete cup is ready Thought you enjoyed the project & Thankyou
