Introduction: How to Make a Neuron
Who doesn't need an extra brain cell from time to time? I mean with all the 'zombies' out there, it seems only right to contribute to the plus column. Enter: Hairy Bobb. He's a brain cell for needy adults. I began making these creatures after a debilitating movement disorder kept me in bed for 18 months. I needed something that was relatively "unmessy" but satisfied my deep need to MAKE stuff! (I come from fine maker stock!) I know these are really just sock dolls, but they seemed to be manifestations of what my brain was doing at the time, and my husband started calling them Neurons. I haven't been able to stop making them since and no two are alike, each having a distinct personality! Watch out, these are rebellious Neurons!
(I have since made a miraculous recovery thanks to the Mayo Clinic.)
What you need to make a Neuron:
- one polka dot sock (but most places make you buy them in pairs)
- matching thread
- ball of yarn
- yarn needle
- an old sock
- beans
- poly stuffing
Step 1: The Unsuspecting Sock
Step 2: Sewing the Head
Turn the sock inside-out and you are ready. Now for some creative leeway...I have photographed Hairy Bobb's head shape, but you can choose something else. I decided on three 'nobbys' on top. Simply sew them with enough space to cut between them with a bit of room to spare. I have used a marker to show you where my seams will go. I do this by hand, because I am usually in bed, but it can easily be done on a machine. When you are finished with the top seam, turn it back right-side out.
Step 3: Stuff the Thing
I take some quilt batting and wrap it around the bean bag before inserting into the body cavity. Work the stuffing and bag around in the sock so the bean bag fits nicely into the heel of the sock, forming a nice "butt" for Bobb to sit on.
Step 4: A Leg to Stand On
Set the little fellow on his butt and determine where the legs come out from the bottom. Because you use the heel of the sock it should be easy to match up the ends of the sock.
Cut the sock in half down the middle toward the body, leaving a little fabric for seam allowance. Now turn the fabric in, right sides together and hand sew the legs shut. The seam is not terribly noticeable if the stitches are small and the thread is a good match. Sock material hides a lot of mistakes.
Leave the end of the legs open so you can put stuffing in there. Don't stuff them completely up to the body because you will need room there for the bend so he will sit easily.
Once they are stuffed to your satisfaction, turn the ends in and sew them shut.
Step 5: Some Facial Features
Disclaimer: Sorry the photo is bad, I stepped into my light. Did I mention this is my FIRST Instructable?
Place the nose on the face of the neuron (here is where some of the character comes to life) and stitch it on. If you would like the nose to match the body of your Neuron, use some of the left over sock. Cut out a circle of fabric roughly twice the size you want the nose to be and stitch around the outside to gather it together. Leave your thread and needle in and gather it up, stuff it and sew it closed. Then attach it to the body.
Arms are also a possibility here, but I opted out.
Step 6: Eyes!
Now that the Neuron can see, they are likely to get into mischief, so keep your eye on them. I'm serious.
Step 7: The MonoBROW!
Start by threading a yarn needle with your choice of yarn (about 5 or 6 feet doubled). If the sock fabric is thin, you will have to be more careful as it won't be forgiving later if you want to pull the yarn out and start over.
Make a series of loops (a bit longer than the final desired length) close to one another as illustrated in the photo. Going across the entire brow will take all of the 6 feet of yarn I have threaded here.
Next cut the loops with scissors. I have found that simply shaking the Neuron vigorously will help the yarn look natural and fall more randomly than using my fingers. I decided to trim up the brow after I shook him. I cut the middle "hairs" shorter so his eyes would be more visible.
Step 8: The Moustache
Cut the loops with scissors and shake into place.
You can call if finished here, but I have plans for the polka dots.
Step 9: Connecting the Dots
After filling them all (except the legs and the front of the "nobbies"), I cut each loop. He's a bit like a wooly mammoth at this point, and my personnal aesthetic pushed me to trim the "hair" very close to the body. Be careful not to pull the yarn during this step as it is likely you will pull it out of an adjacent polka dot since they are linked together. I use my hand to rub the surface to remove loose hair and fuzz the ends of the yarn.
Step 10: Final Photo Shoot
Hairy Bobb Front
Hairy Bobb Back (ew, back hair!)
Hope you have fun. Hairy Bobb has been looking over my shoulder the whole time I worked on writing this (our first) Instructable. He has decided he likes his hair long and wants to grow it out again...Vive la resistance!
