Introduction: How to Make a Paper Airplane That Flies Far
Want to make a paper airplane that not only flies but soars across the room? This step-by-step guide will show you how to fold a streamlined paper airplane designed for long-distance flights. Whether you're a beginner or a seasoned folder, you'll enjoy creating this easy yet effective design.
Tools
  1. 1 A4 size paper.
Step 1: Fold the Paper in Half
  1. Instructions: Begin with a standard A4 sheet of paper. Fold it in half lengthwise (hotdog style) to create a central crease. Unfold the paper to use the crease as a guide for future folds.
  2. Pro Tip: Run your fingernail along the fold for a sharper crease.
Step 2: Unfold and Then Fold the Top Corners to the Center Line.
  1. Instructions: Take the top two corners and fold them inward so they meet at the center line. This creates a triangular point at the top.
Step 3: Fold the Top Point Down to the Edge of the Previous Fold
  1. Instructions: Take the top point and fold it downward, aligning it with the bottom edge of the previous fold. Ensure it's symmetrical for optimal flight.
Step 4: Fold the Upper Sides to the Center Line
Instructions: Fold the two angled edges toward the center line, creating a slimmer and more streamlined triangular shape.
Step 5: Fold the Top About 1/2 Inch (13mm)away From You
Instructions: Fold the top portion of the airplane slightly outward, approximately 1/2 inch (13mm), to create a flap that stabilizes the structure.
Step 6: Fold the Plane in Half Towards You
  1. Instructions: Fold the entire airplane in half along the central crease so the flaps are on the outside. This will form the body of the plane.
Step 7: Fold Both Flaps Out to Create the Wings. the Body Will Be About Half an Inch (13mm) Tall.
  1. Instructions: Fold each side of the paper outward to create wings. The body of the plane should be about 1/2 inch (13mm) thick when complete.
  2. Pro Tip: Slightly angle the wings upward for better lift and stability during flight.
