Introduction: How to Make a Paracord Key Chain
A fun and easy project to make over the summer that's not time-consuming.
- keyring
- paracord
- lighter (optional) and only use if parents are around!!!!!!
Step 1: Step 1
Find the middle of the paracord.
Step 2: Step 2
Take the keyring and slide it onto the paracord.
Step 3: Step 3
Pull the paracord through the loop in the paracord to secure it on the keyring.
Step 4: Step 4
Determine the length you want your keychain to be.
Step 5: Step 5
At the point, you chose your length, bend the paracord into 2 loops.
Step 6: Step 6
Start with the left or right outter most string, and put over the 2 middle strings and under the left or right string(depending on what side you started on).
Step 7: Step 7
Take the string you just put under and bring it around and put it through the right or left loop ( depending on what side again) then pull tight.
Step 8: Step 8
Repeat step 6 and 7 on the left or right side (depending on what side you started with).
Step 9: Step 9
Repeat steps 6,7,8 over again until you can make the keychain anymore ( but leave about a 1 inch left of paracord).
Step 10: Step 10
Tie an overhand knot with the remaining 1 inch of paracord and burn the ends together with a lighter (UNDER PARENTS WATCH AND PERMISSION!!!!!!!!).
Step 11: Thanks for Viewing This Instructable!!!
Please subscribe to my youtube channel Legos r cool and check out my other instructable Altoids flashlight.
