Introduction: How to Make a Pencil Crossbow
This instructable will show you how to make a crossbow out of pencils, rubber bands, and a binder clip. It will also show you how to make ammo for it. Please note that you should stretch out the rubber bands before using them for the best results.
6 Rubber Bands4+ pencils (some are for ammo)1 small binder1 smoothie straw tape
Step 1: Making the Body Pt. 1
Take two pencils and tie them together with 2 rubber bands, do this again with the remaining 2 pencils but only use one rubber band.
Step 2: Making the Body Pt. 2
Take your pencils that you just put together tie the together with two rubber bands like this.
Step 3: Making the Shooting Mechanism Pt. 1
Take the small binder clip and tie to the pencils facing toward the front of the crossbow like this.
Step 4: Making the Shooting Mechanism Pt.2
Take a rubber band and clip it in the binder clip and put the ends in the space between the two "wide" pencils (this is the one time you don't want to stretch the rubber band). Then take the smoothies straw and cut to an inch and tape it on. If you are using a pen equivalent to the size of a smoothie straw then take it apart and tie the "case" down with rubber bands.
Step 5: Ammo
Use pencils.
Step 6: How to Shoot
First, you want to clip the rubber band into the binder clip, then put a pencil through the straw or pen case and open up the bunder clip.
Step 7: Trouble Shooting
If the band used for shooting breaks you could tie the end so that it has a knot on each end. If the crossbow won't shot then adjust where the end of the pencil is sitting.
