Introduction: How to Make a Plate Waist Belt Buckle From a Medal
Find a solid brass panel, let's make a waist belt buckle
You can have all tools and supplies here:
https://www.leathercraftpattern.com/Leather-supplies/DIY-kit/waist-belt-buckle-diy
Step 1:
Let’s make the frame by hand. Use 2mm x 5mm solid brass bar. The inner height is 12mm, inner length is 42mm.
Step 2:
Find suitable places for holes.
Step 3:
Use the positioning awl to prick a small hole, then when you drill the hole, the bit won’t move.
Step 4:
Drill 2.5mm holes.
Step 5:
Bend the panel.
Step 6:
Glue fabric to protect the panel when shooting.
Step 7:
Shoot!
Step 8:
Clamp the frame on reasonable place.
Step 9:
Put a piece of No.51 welding wire on with flux No.51-F.
Step 10:
Heat by torch, Don’t heat the flux directly, burn the other part, use the heat to melt the wire.
Step 11:
Weld the other side by the same step.
Step 12:
Find the stud place by the positioning awl.
Step 13:
Install the tiger teeth clamp.
Step 14:
Cut off the stud’s thread and weld. Because the panel is only 3mm thick, so I weld the stud on, if the panel is thick over than 4mm, I will drill a hole and tap thread for the hole, then only need screwing the stud on.
Step 15:
Polish by sand paper.
Step 16:
Clamp the stud on.
Step 17:
Wrap it by No.51 welding wire with No.51-F flux.
Step 18:
Polish it. Done.
