Introduction: How to Make a Plywood Boat
I spent about a month on this project and it was fun overall and worked like a charm. I suggest you to build this. it is fun when it is complete and the cost was about 500$. used a bunch of stuff for this project including 2 sheets of plywood, wood scrap, pvc piping, marine safe paint, wood screws, flex seal and epoxy
Step 1: Cutting and Measurements
First I needed to cut the plywood out using plans off the web. I used plans of a website called hvartial.kapsi.fi. after I got my measurements I cut out the wood to the right size.
Step 2: Attaching All Sides
After all the pieces were cut out I use a piece of would about 1 inch by 1 inch and about a foot long and screwed in both sides to it from the bow. then I attached the stern using the same method as before. I used wood glue and screws. after everything was screwed in i use a piece of wood 1 inch by 2 inch about 2 feet long to put into he middle to expand the width of the boat.
Step 3: Attaching the Bottom
Then I cut out a rough depiction of the bottom screwed it into the the posts that I put in close to the bottom about 1 inch by two inch's and four feet long. after the bottom was securely attached i use a jigsaw to cut the excess wood that was left from the rough outline.
Step 4: Finishing Touches
I then added custom seats to the boat flex sealed the outside and bottom also using epoxy . I attached a gunwale as well as transom on the stern for a small engine. after I felt like all the wood working was complete I got black and white marine paint and painted the inside white and the out black and white with a stripe. than I finished the waterproofing with a few coats of polyurethane. after I finished painting i added two rods holders for fishing using pvc piping I had laying around
Step 5: Final Product
After a month of hard work me and friends managed to make a fully functional plywood dingy that has a motor and everything you need for safe travels on the water.
Plywood Challenge
15 Comments
1 year ago
Really nice job I respect that you got in there and did it you wanted a boat and you made one nice job already I'm going to try to do it myself and I'm 65
2 years ago
Did you use marine plywood?
Reply 2 years ago
I didn’t use marine plywood because at the time of this project I was getting all my materials at Home Depot but it doesn’t really make a difference as long as you cover the plywood in waterproof paint or sealant
2 years ago on Step 5
Impressive!
2 years ago
looks pretty chill ngl
Reply 2 years ago
I swear paine
2 years ago
Impressive results! : )
Reply 2 years ago
Thanks
2 years ago
The measurements for the side piece do not seem right and it shows on my tablet as a 0 second video. Could you please confirm the side piece measurements. Looks great and I would love to see more views of the outside paintwork.
Reply 2 years ago
The measurements are all correct I don’t know why the website made the picture a video. The reason it looks wrong is because the three measurements in the middle are the post you put in to expand the boats diameter and the rest are just a little complex. If you have any more questions ask me.
Reply 2 years ago
I will also get more pictures of the paint job and engine that I got in the post
2 years ago
The smartest thing I see there is a coat of polyurethane over the epoxy. Epoxy breaks down to a dust in sunlight whereas polyurethane does not .
Reply 2 years ago
Thanks for the feedback!
2 years ago
Well done Adolfo. Must've been pretty chill.
Reply 2 years ago
I swear
