Introduction: How to Make a Plywood Pencil Holder
We needed a way to organize some of the many colored pencils and crayons in our house. This pencil holder was a quick solution and it turned out much better than I thought it would. Enjoy!
Materials
- ¾" Plywood
- Wood Glue - https://amzn.to/2O2iikX
- Spray Shellac - https://amzn.to/2Lsr8H6
Tools
- Table saw - https://amzn.to/2yBtewM
- Band saw
- Miter Saw (or circular saw)-
- Drill - https://amzn.to/2FTwOpi
- Holesaw -https://amzn.to/2LuHFKB
- Chisel - https://amzn.to/2NaXecu
- Mallet
- Clamps
- Forstner bit set - https://amzn.to/30e16eI
- Random Orbit Sander -https://amzn.to/2H2pgCJ
Step 1: Cut the Boards to Size
The first thing I had to do was cut all of the boards to size to be glued up. The boards can be whatever size you want them to be. I used a piece of scrap plywood for this so the size for each board was 12" long and I ripped the pieces on the table saw to about 5" wide. I used five boards for this.
Step 2: Glue the Boards Together
The next thing I had to do was glue the boards together. This was a fairly simple process because it just consisted of gluing a board, and stacking the next one on top of it, then repeat. I did this for all five boards. I made sure that the top board and the bottom board where the best looking boards since they would be showing. I made sure to spread the glue evenly using a scrap piece of wood before putting them together. Next I clamped the stack of boards together with several clamps. I used scrap pieces of plywood on both sides that the clamps were on so the clamps wouldn’t damage the work piece. I waited a few hours then took the clamps off.
Step 3: Cut to Final Size
Next I could cut the block to its final size. From the glue up, it is almost impossible to have the boards in a perfect block, so I needed to trim the sides a little bit. I decided to put a small angle on the sides of the block just to give it a little better of a look but this isn’t necessary. To do this, I used the bandsaw. I angle the top to 5 degrees and then I put a guide on the bandsaw top to keep the piece moving straight. This took some trial and error. If you check out the video, you will see what I did to get this right. After running each side through the bandsaw, I trimmed of the ends of the block with the miter saw. Now I had a block with neat edges.
Step 4: Drill the Holes
The next thing I did was drilled the holes for the pencils. The best way to go about this is to use a forstner bit for it. All you would need to do is mark and drill the holes. I did not have a forstner bit in the size I needed, so instead I used a 2 ⅛” hole saw. This took a few different steps but it wasn’t too hard, it just took a little more time. First I measured where the holes would go. The best way I found to do this was cut a circle using the hole saw with a scrap piece of plywood to help me visualize how they needed to be laid out. Then I could visualize it a little more and use a tape measure to space them out evenly. After I marked the center of all the holes, I used the hole saw and went as far down as I could go creating the outside of the hole. I made sure to clamp the work piece down to the bench so it wouldn't move while drilling. Then I used a 1 ½” forstner bit and drilled into the center of the hole saw mark I made. Then I used a chisel to get the rest of the material out of the hole until the bottom was flush with the hole saw mark. I repeated this several times until the hole was as deep as I wanted it to be, which was about 3” deep. I did this for all four holes making sure they were all the same depth. You can make this design whatever length you want and have as many holes as you want. Four holes was plenty for what I needed this for.
Step 5: Sand and Apply Finish
After all of the holes were drilled, I could start finishing the pencil holder. I first sanded everything up to 220 grit sandpaper. I used a sanding block to get in the holes and a random orbit sander to get the outside parts. Next I used spray shellac on the workpiece. I sprayed 3 thin coats on it letting it dry for about 20 minutes between each coat. This left a nice finish on it.
Step 6: Complete
After this, the project was complete! Check out the video to get more of a visual idea of what I did. Feel free to reach out to me if you need help or have any questions. You can send me a message or find me around the web. Thanks for reading!
Youtube - https://www.youtube.com/madebymitch
Website - http://madebymitch.net
Instagram - http://www.instagram.com/made_by_mitch
Twitter - http://twitter.com/made_by_mitch
