Introduction: How to Make a Pretty Bracelet!!
This Instructable will show you how to make a pretty bracelet
Please subscribe to my channel
Step 1: Gather Materials
You will need :
1. 71 Beads
- 60 Crystal Beads
- 48 Blue & 12 Yellow
- 11 Pearl Beads
2. Fishing Line or String
3. A Clasp
4. Scissors
5. Nail Polish or Permanent Marker (Optional)
- You will Use the nail polish or permanent marker to paint one end of the fishing line or string
Step 2: Fold Fishing Line or String in Half & Tie Knot
1. Cut a piece of fishing line or string
2. Fold fishing line or string in half
3. Hold both ends together and slide your fingers all the way down to the end
4. Tie a knot, leaving a loop at the end
5. Paint one end with the nail polish or permanent marker
Step 3: Make Circle #1
1. Put 1 blue bead on the left end (Painted)
2. Put 1 blue bead on the right end (Clear)
3. Let the beads fall to the centre
4. Put 1 yellow bead on the left end (Painted)
5. Pass the right end (Clear) through the bead in the opposite direction
6. Hold both ends of the string even
7. Pull tightly to the center
Step 4: Make Circle #2
1. Put 1 blue bead on the left end (Clear)
2. Put 1 blue bead on the right end (Painted)
4. Put 1 pearl bead on the left end (Clear)
5. Pass the right end (Painted) through the bead in the same direction
Step 5: Make Circle #3
Step 6: Make Circle #4
Step 7: Make Circle #5
Step 8: Make Circle #6
Step 9: Make Circle #7
Step 10: Make Circle #8
Step 11: Make Circle #9
Step 12: Make Circle #10
Step 13: Make Circle #11
Step 14: Make Circle #12
Step 15: Make Circle #13
Step 16: Make Circle #14
Step 17: Make Circle #15
Step 18: Make Circle #16
Step 19: Make Circle #17
Step 20: Make Circle #18
Step 21: Make Circle #19
Step 22: Make Circle #20
Step 23: Make Circle #21
Step 24: Make Circle #22
Step 25: Make Circle #23
Step 26: Make Circle #24
4. Tie a knot
5. Tie one more knot
Step 27: Attach Clasp
1. Put the clasp on one end of the string
2. Pass the other end of the string through the clasp in the opposite direction
3. Hold both ends of the string even
4. Pull tightly to the center
5. Feed the right end of the string through the right bead
6. Pull tightly
7. Feed the left end of the string through the left bead
8. Pull tightly
9. Feed one end of the string through the yellow bead
10. Pull tightly
11. Tie a knot
12. Tie another knot
13. Feed the right end of the string through the blue bead
14. Feed the left end of the string through the yellow bead
15. Cut the string
