How to Make a Rain Poncho Out of a Shower Curtain
28,985
37
5
Introduction: How to Make a Rain Poncho Out of a Shower Curtain
About: Threadbanger is a network for people who love to DIY, recreate, refashion and craft. Forget about corporate stores, we're here to help you create and find your own style! From our episodes, forum and blog to o…
Rob and Corinne of Threadbanger are at it again, this time re-using and recyling a shower curtain! Take one of your shower curtains and make it into a unique rain poncho following these directions. For more info, watch the video! Want to make more recycled and individual fashion? Subscribe to Threadheads on iTunes!
Materials:
Shower curtain, sewing machine, nylon thread (we used transparent), tissue paper, leather sewing machine needles, scissors, tape measure, ruler, permanent marker
Have fun!
Step 1: Vinyl Sewing and Shower Curtain Preparation
First, some basic vinyl sewing tips using your regular sewing machine with no special attachments:
Put a leather needle on your machine, thread a bobbin of the nylon thread, and set a stitch length to 3 or higher. Place the tissue paper between the vinyl and the feed dog so that the vinyl doesn't stick, and start sewing. Be careful not to sew on the same spot more than once or it will weaken and rip easily. When you're done, tear the tissue paper away and voila!
If you're using an old shower curtain, be sure to wash it very well first. We highly recommend some of the anti-mold cleaner Meg made on an episode of Decor it Yourself.
Keeping these tips in mind, now it's poncho time!
Step 2: Cut the Shower Curtain Into Poncho Shape
Measure and cut the shower curtain 55 inches wide by its existing length, which measured about 67 inches for us. Cut off any seams, including the top piece that has the holes for shower hooks.
Draw a 12-inch line parallel to the bottom seam in the exact middle of the rhombus. Cut along the line. This is the head hole.
Step 3: Making the Hood
Take out the extra piece you cut off, fold it in half right sides together, and draw a hood shape starting from the fold. (If you need help making a hood shape, try tracing a hood from a shirt you already have. But make sure you don't cut the fold apart!)
Cut out the hood shape and sew a seam along the back curve.
Step 4: Attaching the Hood to the Body
Take out the body section and cut a 2-inch slit in the middle of one side of the head hole. Fold the flaps under and pin them down to make the front neck opening of the poncho. Pin the hood inside of the hole. It helps to carefully try it on a couple times and make sure it lays right.
Sew the hood onto the body, making sure to sew all the way around the hole.
And you are now prepared for all those spring showers!
Be the First to Share
    • First Time Author Contest
    • Remote Control Contest
    • Backyard Contest
      Backyard Contest
    5 Comments
    WessexGir1
    WessexGir1
    3 days ago
    A lightweight shop bought poncho blew up in front or behind - until I weighted by threading a piece of chain through the hem. Can stitch in or leave as removable. String & washers world also work?
    JoreneD
    JoreneD
    11 years ago on Introduction
    Polyester fabrics used for shower curtains / liners are available in a variety of colors, are machine washable, repel water, easier material to sew, and drape nicely. Softer and more pliable than vinyl, smaller when folded, lighter weight for packing along with you, and you can even make a carry pouch.
    Seal the seams to reduce / prevent leaking. There are products - such as backpacker outerwear laundry accessories - you can use to increase or refresh the "repel water" status.
    Also consider making the hood a bit deeper and adding a drawstring around the face so you have more control over where that hood stays. Get creative and you can also add some stiffening and create a visor for additional rain protection of the face.
    For safety and to increase your visibility to others out on a stormy day, lighter and brighter colors are recommended.
    wyldethang
    wyldethang
    13 years ago on Introduction
    works well with old plastic table cloths too, esp the cloth backed ones provide a little warmth if your cold.
    skeptikool
    skeptikool
    14 years ago on Introduction
    I've found these discarded curtains quite frequently and have kept them for waterproof covers for mowers and things. Similarly, I made a poncho from one of those nylon sheets that you hang above a small tent. Snag was, it was water-resistant, not waterproof - but still performed quite well. I used mine for cycling and after a couple of really frightening experiences, I'd like to pass on a tip that could save one from disaster. On one occasion, while cycling on major highway and with tractor-trailers passing at high speed the back of the poncho blew over my head totally obscuring my vision. At another time, cycling into a strong wind, it was the front of the poncho that lifted and rendered me temporarily blind. If for cycling wear, have the back of the poncho long enough so that you can sit on it. If your bicycle doesn't have a rear fender, this will also keep your backside dry. Attach a couple of ties to the bottom of the front of the poncho so that you can secure it from lifting. It wouldn't hurt to include a strip of reflective tape back and front, also. A good and useful instructable.
    IdahoDavid
    IdahoDavid
    Nice reuse-recycle concept. Old shower curtains also make nice ground clothes for camping. My wife has one in back of the van she uses to lay down whenever she has to move something messy, like when we get the regular tires switched with the snow tires, etc. Also useful if you need to get rid a body, but that's another story.
