How to Make a Raised Garden Bed Cover With Hinges
Intro: How to Make a Raised Garden Bed Cover With Hinges
This Instructable will take you through the process of making hinged covers for your raised garden beds. This will help you keep all the wildlife out of your garden and prevent them from eating all your plants.
A bunch of my plants that were well established, were all eaten the other day - likely from an adorable bunny in my yard. So, I was on a mission to fix this problem fast! So, let's get started!
STEP 1: Supplies Needed for Hinged Raised Garden Bed Covers
I made two raised garden bed covers for garden beds measuring 4 feet by 6 feet in length. I made one cover larger than the other and I will share the measurements I used for both of them. You will need to figure out how to make it work for you, depending on the size of your raised garden bed. One of my garden beds has plants will get quite large, so that is why I made the cover so big. The other one will have smaller plants and did not need a cover quite that large.
If you have questions, let me know.I will be updating this later with links to some of the items I used, in case you are interested.
Wood Cuts
- (4) 1x2x72in
- (4) 1x2x47in
- (4) 1x2x36in or (4) 1x2x16in
Optional for Large Cover
- (8) wood corner brackets for extra stability
- I used scrap 1x2 board and cut them about 5 inches long
- See image above for example
Tools & Supplies
- A miter saw to cut the wood to size (or have Home Depot cut the pieces for free)
- measuring tape & wood glue
- a drill (I am using the Matrix and love it)
- Kreg Pocket Hole Tool (any type will work fine - I bought the Kreg Pocket Hole Machine & Used it)
- Screws - I used the 1 1/4 inch Kreg Pocket Hole Screws
- Plastic Fencing - I bought this from Walmart.com - but this one from Amazon is larger & would work better
- Staple Gun to use to attach plastic fencing
- Hinges (at least 2 per cover) - I used ones that were small as that is what I had. Larger would be best.
- Clamps or something to secure wood after glued (I used bricks)
- Optional: wire (I used jewelry wiring to "sew" the fencing material together)
Holly Mann is a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for sites to earn advertising fees by advertising and linking to amazon.com.
STEP 2: Cut the Wood, Pocket Holes & Glue
The first thing to do is to cut all the wood to the correct dimensions. I used a miter saw and it made it fairly quick and easy. I suggest going out to your raised garden bed and taking the measurements, to make sure they are 100% accurate. I say this because my measurements were slightly off in the end due to the outdoor boards being slightly warped from the weather. So, although I thought I had correct measurements, they were a bit off. And, you must also take into account that you will be using pocket holes to secure the sides and this will affect the length and width of the cover you make.
After cutting the pieces, it is now time to make pocket holes. Take out your Kreg pocket hole tool and set it to the correct measurements and drill one hole into the end of each 47 inch board (4 of them) - one hole on each end of the board on one side. Then, also take out your leg pieces which are either 36 inches long or 16 inches long and drill pocket holes into the top and bottom of them also.
Now, lay out your boards on the ground (see image) to create the rectangular shape. Once the pieces are in the right place, take some wood glue and place it on the end of the shorter 47 inch boards and push that up against the end of the 72 inch board (see image). I used bricks to hold the boards in place as the glue dried. You can use a clamp if you have one large enough. Once the glue is dry, I then took out my 1 1/4 inch pocket hole screws, and drilled them into the pocket holes to secure the whole piece together.
I recommend doing the second piece (for the top) at the same time, if possible.
STEP 3: Attaching the Legs to the Cover
In this step you will be attaching the legs to the base. If you are making the very large cover, and you would like to add support brackets to the corners, first do this before continuing. I used my Kreg Pocket Hole Machine to make these pocket holes on the small corner bracket pieces. I cut the 8 pieces with the miter saw first, with a length of approximately 5 inches on the longest side. I managed to use some glue and small 3/4 inch pocket hole screws to attach them to the board. Once that is done, it is time to add the legs to the base.
The legs should have a pocket hole on the top and bottom (see image). Take a little glue and put it on the bottom of the leg board and set it on the corner area of the board (please see image to understand what I mean). Use a brick or clamp to hold it in place as it dries. Once it dries, drill a pocket hole screw in there to secure it to the base. Once all four corners are done, you will then be able to finish securing the whole structure together.
For me, after the bottom part had the legs attached, I then flipped it over and onto the other piece. I then used a little glue to secure it, before I drilled it together with the final four pocket hole screws.
STEP 4: Securing the Plastic Fencing to the Cover
It's now time to flip the cover over so it is right-side-up and begin securing the plastic fencing to the structure. I really love the plastic fencing that I bought, though it measured at 3 feet tall, it was off by two inches. This ended up causing me a lot of issues. So, be sure to calculate things and figure out the best orientation for your fencing material, so you can do the least amount of work possible! It was quite a lot easier and faster for me to do the smaller cover. I bought two rolls of fencing material and had more than enough to make three covers I will be sure to share a link to where I bought it, in the supplies step.
Take our your staple gun, and carefully start at one end by stapling the fencing material to the cover. Pull it tight and secure as you go along. I also had a few issues where the staples weren't in all the way, so I used my heavy hammer to hammer those in. Cut off any excess. If you have areas where you need to use two pieces of fencing and there is a hole where little critters can get it, you will need to fix this. I used wire (some cheap, thin wire that was from JoAnn in the jewelry-making section) to secure the two overlapping fencing pieces together. If you are good at stapling, this will not take too long. Cut off any excess fencing material.
STEP 5: Finally, Add the Hinges to the Raised Garden Bed Covers
Now it's time to add hinges to the bottom edge of your garden bed. Be sure you know exactly where you want to put them. On my smaller garden bed, I had hinges on the end due to space issues. On my larger one, I had it on the six foot side. Please note, my hinges are way too small and will be replaced soon. I used them because they are all that I had at the time. On my large bed, I used three hinges. On the smaller one, I used two. I did not add anything like a chain or rope to assist once the cover is opened up. For me, I just set something underneath the area where the large cover goes once it is opened up. It could rest on the ground, but I didn't want to put extra strain on the hinges right now since they are quite small. You can also screw in eye hooks and a short rope or small chain so that when you open the cover, it is also held up by the chain or rope. I hope that makes sense. If not, let me know and I will link to a tutorial or add it on here myself.
For the placement of the hinges, I just figured out the center of the board. Then, I tried to place the two (or three) hinges about equally apart. I then marked with a pencil where the holes will go and then drilled in three small holes. Then finally, I drilled in the small screws to secure each hinge.
Once outside, I placed the cover on top of the bed and centered it exactly where I wanted it to go. Then, I did the same thing I did inside. I marked the hole placement, drilled small holes and then drilled in the screws and secured it in place.
If for some reason your garden bed wood is warped slightly and your measurements are slightly off (leaving a hole or space anywhere) then do not worry too much! Take some extra plastic fencing material and your staple gun outside with you. Cover that hole or space with a small piece of plastic fencing material. In my area, I have a massive number of rodent-like creatures - from squirrels to chipmunks and also lots of adorable bunnies that love eating my plants. So, I must be sure to cover up every single area of these raised garden beds. So, if you see any holes in the wood (mine had one) then also cover that with some plastic fencing.
If you have any questions at all, please feel free to ask!
31 Comments
waterlovinguy 3 years ago
dj9281 5 years ago
fossil300 5 years ago
The lead photo of your garden beds, including text about the instructable, has been linked on Pinterest to this unseen URL and a visual ID of rustickitchen.info:
https://homedbs.com/create-a-micro-garden-for-smal...
Just thought you'd like to know. I googled enough about the project to find the real instructable.
PitStoP 6 years ago
I forgot to say congratulation on your win. You deserve it! =)
PitStoP 6 years ago
Great idea Holly wish I had made these years ago to keep the animals away from my garden. I don't know if it will keep the deer away which was my main problem. I will remember this when I make new beds next time, I don't have any beds up this year. Will work great with plastic for a green house affect. =)
ChrisD142 6 years ago
just wonderful! You Are Quite CREATIVE ,,!!!
4DIYers 6 years ago
Excellent write up! A perfect way of keeping the critters out while still maintaining a clean design. Thanks for sharing :)
HollyMann 6 years ago
Thanks 4DIYers! :))
LorantS1 6 years ago
Great instructable. Thank you. I was going to build raised garden beds and then cover them all with an "igloo" of bird netting supported by 40mm poly pipe (irrigation pipe). The problem with the igloo is that if a bird gets in, and inevitably they do, then they wreak havoc on the entire garden. Also, I thought of using aviary wire (half by half inch light mesh) but that would make the cover too heavy. Bird netting is light weight and simpler to fix. Your technique is simpler and less complicated. Love it!
Thanks for the comment Lorant! I see what you're saying with your idea. It's hard to figure out what to do - so you don't waste your time making a garden and having the animals eat it all. I also was thinking about using PVC..though I prefer to stay away from it - it might have been a cheap option. The fencing available at Menards is all pretty heavy and thick and not fun to deal with (ie: chicken wire). The bird netting I found on amazon (wish I found it before I bought this stuff from walmart) is much larger than the walmart stuff I bought...so it would save some time because I had to splice pieces together. :) Are you going to still build the garden beds for this summer? Hope it works out well!
Thanks Lorant. Good luck with your upcoming project. So crazy to hear about trying to avoid kangaroos and wallabies! Makes me wonder if they are as common as deer are here in the states where I live. :))
DavidN87 6 years ago
I just had to free a Robin from mine about an hour ago. This fits the solution bill perfectly. Previously had plastic fencing, but squirrels (Sid and Sally) and other small rodents (including Chappie the chipmunk) kept chewing holes in it. Replaced with metal chicken wire recently. Thank you so much for this instructable! This will be built abit modified to my needs, and i plan onto sharing as a "I made it!" Great Work & and keep it up!
Thanks for the comment, David. :) I hope it works out well! And, so far I haven't had any squirrels or other animals chew through this (luckily) and hope they do not! Good luck with your project and so happy you stopped by!!!
beer20 6 years ago
gismo1 6 years ago
I have been looking to make something similar for my raised garden beds in which I am growing cabbages and cauliflower. the size of your beds might differ from mine slightly, but that's not a problem so thanks.
Barry6470 6 years ago
I made the exact same thing for my Strawberry Beds and Rhubarb, they are great for keeping those pesky birds away and any cats that happen to feel hungry.
That is awesome Barry. Did you have to make a larger one for the Rhubarb? We have some growing in our yard and it's pretty big. Great to hear other people have made a similar thing. I saw an image of something like this on Pinterest ages ago but never found a tutorial on it...so I did it myself.
The Rhubarb if you let it can and will take over a patch of ground, the one we have is about 3ft square and boxed in so it doesn't spread. The cover is the same as mine and yours, just in the 3ft size. We have constantly had loads of Rhubarb, and the other day after pulling most of it out, has now grown again, the stuff is crazy but nice to eat. If you have trouble with cats etc try putting plastic forks upside down in the soil, as you can imagine they don't like it ha ha.
deluges 6 years ago
Just sent that to my grandpa as an idea for cat protection. They pee on his salads. Great project :)
