Introduction: How to Make a Real Bubble Solution
Here i am showing you how ot make a real best bubble solution using
guargum.The ingredients here i am using is little bit different to get a perfect output. Its a output is 100% sure and the bubble solution is better than the one we buy from market
Step 1: GuarGum Bubble Solution
Its very easy to make.We can make this bubble solution in 2 minutes with normal ingredients. GuarGum is the special ingredient here we used.
Step 2: Ingredients
1. 250ml hot water
2. 750ml normal tap water.
3. 1/4 tbsp GuarGum
4. 2 tbsp of rubbing alcohol
5. 50ml dish wash soap
6.1/2 tbsp of baking powder
Step 3: How to Make
- Mix 1/4 tbsp of gaurgum with 2 tbsp of rubbing alcohol and make a good slurry.
- Take 250ml of hot water and add the guargum slurry in to it and mix well.
- Add 750ml of normal water in to the mix and combine and mix all together.
- Add 50ml of dish wash soap and mix well.
- Add 1/2 tbsp of baking powder and mix.
- Remove the foam on the top of the solution.
- Bubble solution is ready.Keep the solution overnight for best result
