Introduction: Reusable Fabric Gift Bag
This year I’m encouraging friends to re-gift my presents!
Well, the gift bags anyway, I’ve made some drawstring fabric bags, and am giving (usually handmade) gifts in these re-usable bags, with an encouraging label to pass them on.
These bags are pretty easy to make if you are a sewer, and can be made
to fit the gift inside, I’ve put together this free step by step tutorial for anyone to use, as I feel its really important that we share any of our ideas for reusing and recycling. You can also find it up on my website in the Tutorials section.
I made my bags using a sewing machine and an overlocker, but you can complete this bag easily with just a sewing machine, I have written the instructions for those of you with just a sewing machine, and those lucky enough to have an overlocker / serger as well.
For my bags I used a printed calico cotton, a natural fabric with a bit of stiffness seems to work well and holds its shape, I would suggest using heavy dress material or lightweight upholstery fabric. If you can, use up fabrics you already have – I bought my fabric back in a sale some months ago.
Fabric & thread
Drawstring material -thin string, thin ribbon or lightweight cord
A clear flat work surface
A sewing machine
An over locker / serger machine (optional)
Scissors
Rotary cutter (optional)
Thread un-picker / ripper
Pins
Marker pen that will erase with heat or water or chalk
Large blunt needle or safety pin
Step 1: Estimate Your Fabric Requirement
Spread out a single layer of your chosen fabric on a flat surface. I use
a gridded cutting mat to help me get the edges straight. Estimate the amount of fabric you will need by placing your gift on top of the fabric and loosely wrapping the fabric around your gift. If you want to make the most of a design on the fabric remember you will fold over about 1¼ ” of fabric from the top that won’t be visible on the bag.
Prepare your fabric for cutting by pressing with an iron.
Step 2: Cut Your Fabric
Cut out a square or rectangle of fabric to your estimated size, if the
fabric has a definite linear pattern (as mine does) try to line up the pattern lines with your cutting lines.
Fold your fabric in half, wrong sides together, cut along the fold line to create two pieces of fabric. This will create 2 side seams that are needed when we get to the stage of threading the drawstrings through the top edge of the bag.
Trim all four edges so that they are straight. Either draw lines with a ruler and cut along with scissors, or use a straight edge ruler and a rotary cutter.
Step 3: Start Stitching the Seams!
With right sides together, join the front and the back fabric pieces together along the lower edge with a line of stitching.
You can do this either with a straight stitch (recommended stitch length 2.5) and finish raw edges with a zig zag stitch, or use an over locker / serger to stitch seam and enclose raw edges at the same time. In both cases trim threads at start and end of stitching.
Fold up bag bottom seam by approx 25mm or 1″, or if you have a particularly boxy gift, roughly measure it’s depth, divide in half, and fold up the lower edge by this amount. For example I would turn up a bag that will be used for a bottle of wine by 50mm or 2″. Press with an iron.
Sew both side seams of bag together. If using a sewing machine reinforce the stitches at the bag bottom end of the seam using the reverse function, and zig zag the raw edges to finish.. If using an overlocker, leave a 50mm or 2″ thread chain at lower edge (top edge will be enclosed in a hem so can be trimmed off).
Thread the chain onto a large needle and thread through the loops of the side seam and trim to finish.
Step 4: Measure and Fold Drawstring Hem
The top hem on the bag needs to be deep enough to accommodate your drawstrings.
With bag turned inside out, begin by turning over a 6mm or ¼” hem, press in place. Turn over a further 25mm or 1″ of fabric to create the main drawstring channel. Use a ruler to help make sure you have the right depth.
Press with an iron. Pin top in place if you need to.
Step 5: Make Drawstring Openings
Turn bag right side out and mark an opening on the side seams of the bag where your drawstrings will be pulled through. This opening has to be within the boundaries of the 1″ top hem. I used a pen that erases with heat (from the iron) or you can use a washable pen or chalk pen, but as you will be marking the outside of the bag you don’t want to use anything permanent.
Using an unpicker / ripper cut through the side seam stitches between your marks, turn the bag inside out and completely unpick this section of the seam. This forms the little holes in the side seam that you will pull your drawstring through.
Turn the bag right side out again, and sew a straight stitch box around the opening (the yellow lines show the stitching lines in the right hand picture). This reinforces the opening, and effectively seals the unpicked side seam stitches.
Step 6: Stitch Drawstring Channel
Now its time to sew the channels along the top hem, I found it easier
to sew the lower edge from the inside of the bag – following along ¼” or 6mm from the folded edge and then turn right side out and sew the top channel approx 12mm or ½” from topmost folded edge. This forms the channel you will thread your drawstrings through.
You now have a hemmed gift bag, and that’s all your machine sewing done!
Step 7: Threading the Drawstrings
Take your drawstring material, in my case I used a thin piece of twisted unbleached cotton string to match the calico fabric I have used. Measure the string to 2½ times the width of your finished bag, and cut 2 pieces. The aim is to create 2 drawstrings that you can pull from either side of the bag.
Using a large blunt needle or safety pin thread your string in through the side openings of your bag that you made in the top hem. Thread one string in from the right hand side – thread right through the channel and come out the same opening you went in, do the same from the left hand side.
With the bag flat on your surface, leave about 25mm or 1″ of the string and tie a simple knot on either side of the bag – trim excess thread. This gives you two strings to pull apart from either side of the bag to close the top with a gathering action.
Step 8: And There You Have It! a Bag Ready for Re-gifting.
Encourage your friends and family to re-use your bag pass it on, and help reduce the amounts of wrapping paper going to waste.
Karen’s Top Tip
"At each step of the construction process, pressing the fabric with an iron will increase accuracy, and result in a a professional looking finished item with straight seams and crisp edges."
