Introduction: How to Make a Ruler: Step 1
Put down the box shape, make it in to a rectangle and flatten it out.
tickercad, an electronic device and WiFi
Step 1: Step 2 Go to Shape Section Get Correct Shape to Make the Ruler
get the tube shape make it thin and tall you will need 2 of these
Step 2: Step 3 Line Up the Shapes to Be Perfectly Lined Up to the Rectangle
Go the the shape section and line them up to be connected to the rectangle also make sure they are the exact same size at well to make it accurate
Step 3: Step 3 Go to the Shape Section and Get the Squares
after you line the tubes together get 4 squares and line them up by inches as you can see in the photo. All measurements are on photos
Step 4: Step 4 Get the Numbers for the Shape Section
go to shapes and number and get 1,2,3,4,5 and put them on top on the ruler to make the ruler measure by centimeters.
Step 5: Step 5 Line Every Thing Up
make sure to line up everything and make everything connected together
Step 6: Finished
You have finally made you ruler congratulations 🎉
