How to Make a "Run Through the Sprinkler" Sprinkler
49,110
184
23
Featured
Introduction: How to Make a "Run Through the Sprinkler" Sprinkler
Step 1:
Step 2:
Step 3:
Step 4:
Step 5:
Step 6:
Step 7:
Step 8:
Now use the cement to glue the slip end of the female hose adapter to the end of the 5 inch piece.
Step 9:
Now use the clear cement to create a square of PVC pipe, with the 4 long sides and the 4 - 90 degree corners.
Step 10:
Now come that part that I messed up bad on. I drilled too many of too large of holes on each side of the square. Too many holes mean not enough pressure, so no water squirting out or the pipe. So this time I drilled 10 – 3/32 inch holes on each side. I had each hole slanting in a different direction than the hole beside it.
Step 11:
Then I hooked the hose up to it and turned on the water. This is the result. Enjoy!
Maker Moms Contest
Hurricane Lasers Contest
23 Comments
7 years ago on Introduction
You have completely ripped off my post from my blog. I would appreciate you removing this material. Giving my site credit for the idea and the completely recreating exactly as instructed is wrong. If you do not change the design by at least 30% then you are not allowed to use mine without permission. If readers want to know how to make it, they can isit the orignal post at... http://myhomespunthreads.blogspot.com/2011/05/day-25-homemade-sprinkler-with-she.html
9 years ago on Introduction
Do you think 1/2" PVC would give you more pressure than 3/4".
Using 1/2" would reduce the number of holes you could drill as it cuts down the volume of water. Just as using 1/2" PCV on a sprinkler system reduces the number of heads you can put on a zone. If your purpose is to make the sprinkler spray higher, drill smaller or fewer holes.
But doesn't that depend on the pressure coming out the hose? If pressure isn't enough to fill 3/4" to capacity than yes 1/2' would? Right?
The rule of thumb for spray bars is to have the total area of all of the drilled holes to be slightly less than the area of the inside diameter of the tubing you’re using. For instance if you're using 1/2-inch tubing that has an internal cross sectional area of .196 square inches you need 13 holes at 9/64” diameter, 16 holes at 1/8” diameter or 21 holes at 7/64” diameter. This rule insures that you won’t lose any pressure in the bar.
I'm having a hard time wrapping my head around that math but I think I got the intent. Helpful tip!
I think that you could also use a Hula Hoop. Make a cut, attach the t-joint, drill the holes and there you have it.
I have used something similar for an awesome outdoor shower head (upside-down of course).
A great shower head would be to drill a few very small holes all around the bottom of a 2 liter bottle, screw the bottle on to a garden hose and drape the hose over a tree limb, then turn on the water. Enjoy!
@craftknowitall; Hi! I like how you show what happened the first time and how learned; also how you like to learn from another article then do it yourself. Tweeting you now. Cheers! Site
Sorry I don't tweet. Thanks for commenting.
ABSOLUTELY FABULOUS!
took the kids to a water park yesterday and was amazed that their favorite spot was a timed sprinkler system. within a 10 ft. sq. area, small fountain heads on all four corners, largest in the middle ~ two small ones may shoot up at one time but you never knew which ones it would be. certainly kept the kids laughing and jumping, especially when the largest, center fountain head erupted. each fountain would spray for about 2 minutes before stopping as another would begin.
Would love to know how to create this timed system.
Well mine looks just like your first one. The directions neglected to mention anything about how many holes to drill. I can't replace my parts so, I'm trying to come up sith something I can paint over the PVC that would stop up the holes and then I'll drill the correct number. SUGGESTIONS?
I made a water bar that I messed the math up on. I used electricians tape and it lasted for the 40-50 hours I used the water bar.
Cover them with Gorilla tape. Even better would be to plug the holes with a small piece of dowel and then use the tape. If you have enough holes, the pressure shouldn't be enough to leak through.
Try pluging some of them with sugru
9 years ago on Step 11
this would be easily adaptable for garden beds... similar to a custom drip system, but easier to use and cheaper. Just make the pieces the size you need for your beds and drill holes as needed for each bed or plant...
Nice, and very simple. I constructed one from the Kidwash 2 Instructable https://www.instructables.com/id/KidWash-2-PVC-Sprinkler-Water-Toy/ that uses misting jets - more expensive, but requires fewer holes and water pressure is not a worry.
I'll have to make one fo these for my dog. She loves to attack streams of water. Great instructable!
This would be perfect to put around the perimeter of a raised garden. I was going to use a soaker hose but now that I see your idea I think I will build this instead! Thanks!
