Introduction: How to Make a Rustic End Table
This simple DIY end table has a modern-rustic appearance and can be made in a single day. It is very affordable to make at only around $40 in materials, but can sell for much more!
I have a detailed set of plans available for this project, which you can get by clicking here.
Step 1: Cutting Parts to Length
I start at the miter saw but cutting all of my parts to length.
Step 2: Ripping Parts to Width
I then move to my table saw and rip all of my parts to width.
Step 3: Cutting an Angled Edge
Next I cut a 45-degree angle on each of the leg piece edges. This will become a miter joint for the leg assembly.
Step 4: Making a Taper
I use my tapering jig to cut a small taper on the bottom side of each of the leg pieces. This step is optional, but adds a layer of décor.
Step 5: Leg Assembly
I now spread some wood glue on each face of the leg pieces. I secure the leg pieces to each other with a miter joint, using 18-gauge brad nails.
Step 6: Adding Top Supports
I begin adding the top support pieces to the legs with wood glue and brad nails. I work my way around the table, installing each side of top support pieces.
Step 7: Adding Bottom Supports
I then install all of the bottom support pieces in a similar fashion with wood glue and brad nails.
Step 8: Installing the Top
I install the table top pieces using brad nails, ensuring the overhang/reveal on all 4 sides is even.
Step 9: Adding Shelf Pieces
I install the shelf blanks onto the bottom support pieces using brad nails.
Step 10: Sanding the Project
I give the project a thorough sanding, working my way through the grits.
Step 11: Applying Finish
I liberally apply wood stain, then wipe off excess after it’s had time to make it’s way into the wood fibers. Once the stain has dried, I spray a coat of Lacquer on the table, and this project is complete!
