Introduction: How to Make a Scraps Folder
This is an easy-to-make and eco-friendly folder/envelope that can be used to carry an assortment of art-stuff from fabric swatches to inspirational finds from magazines.
Step 1: What You Will Need
Materials
- 2 FedEx large pak envelopes(tear and water resistant)
(found at FedEx Kinkos)
- scissors
- tape
- cardboard
- sewing needle & thread(can be used instead of tape)
Step 2: Cutting the Envelopes
Cut 2 fedex envelopes as illustrated
Step 3: Unfold Envelope
See image provided
Step 4: Attach Pieces Together
This can be done by sewing or taping. allow for about 1" of overlap.
Step 5: The Folding Begins
Directions Provided by “Origami Easy to Make Paper Creations” by Gay Merrill Gross
See imageprovidedfor illustrated instructions
1. Have the side you want to be seen on the outside of your Scraps Folder facing towards you.
Bring the short top edge down to meet the short bottom edge, folding the paper in half.
2. Bring the bottom raw edge (front layer only) up to the top folded edge. Crease and unfold. Turn
over and repeat on the other side.
3. On the front layer, fold the bottom raw edge up approximately 1/2 “ to create a small hem. Then
turn your model to the back and fold up a matching hem on the back layer.
4. On the front layer, fold the bottom corners up to the horizontal crease. Turn the model over and
repeat.
5. On the front layer, refold on the existing horizontal crease. Repeat on the other side.
6. Unfold the folded edge.
7. Rotate your paper one-quarter turn, so the short edges are at the top and bottom.
8. Fold down the top edge to form a hem approximately 1” wide.
9. Notice the two triangular pockets at either edge of the hem. Bring the bottom edge upward and
insert its corners into the triangular pockets. Slide the bottom edge as far up as it will comfortably
fit inside the pockets and then make a firm crease along the new bottom edge.
10. Fold the left side of the model over to almost touch the right side. Leave a small gap. Crease
firmly then unfold. Repeat. Bringing the right side almost to the left. These two fold form the
spine of the case.
11.Your case is now complete. You will now have 4 pockets to hold all your artistic inspirations
