Introduction: How to Make a Seedbed With Recycled Material
Do you want to start growing some of your food? The important thing is to start right from the seedbed.
¿Quieres empezar a cultivar tu propia comida?
Step 1: Materials
- Plastic cups
- Potting soil
- Seeds
- A drill bit or something to open holes
- Vasos reciclados
- Tierra para macetas
- Semillas
- Una broca o algo para abrir agujeros
Step 2: Open Holes in Plastic Cup
Open holes in the bottom of the plastic cup, this will help to drain the seedling and avoid the apparition of fungi that can prevent the germination of the seed.
Abrir agujeros en el fondo del vaso plástico para que sirvan de drenaje, así evitaremos la aparición de hongos que puedan impedir que la semilla germine.
Step 3: Fill the Plastic Cup With Soil
Fill 1/4 of the plastic cup with potting soil, before placing the seeds you must moisten the soil with a spray, this for two purposes:
- The seed is prevented from "moving" from where it is planted during the first irrigation.
- It is verified that the seedbed has good drainage.
Llenar 1/4 del vaso plástico con tierra para macetas, antes de colocar las semillas deben humedecer con un pulverizador la tierra, esto con dos fines:
- Se evita que la semilla se "mueva" de donde se plante durante el primer riego.
- Se comprueba que el semillero tiene buen drenaje.
Step 4: Plant the Seed
The number of seeds to be planted in each plastic cup will depend on their size, as well as the number of plants they wish to grow, taking into account the following:
- Placing two or more seeds per hole, because not all seeds will germinate, it is guaranteed that at least one will germinate.
- After placing the seed, cover with a little more soil and irrigate with the sprayer, this time in less quantity due to previous irrigation.
La cantidad de semillas a plantar en cada vaso dependerá de su tamaño, así como de la cantidad de plantas que deseen cultivar, tomando en cuenta lo siguiente:
- Colocar dos o mas semillas por agujero, debido a que no todas las semillas germinarán así se garantiza que al menos una germinará.
- Luego de colocar la semilla cubrirla con un poco mas de tierra y volver a regarla con el pulverizador, esta vez en menos cantidad debido al riego previo.
Step 5: Finally
- The seedbed should be placed in a place where it receives direct sunlight.
Always keep the soil moist - Wait one or two weeks depending on the seed used (cherry tomato in this example).
- When the plant has at least 4 true leaves, it is transferred to a larger pot
- If germinates more than one seed per hole can choose the plant to develop faster and cut the others.
- El semillero hay que colocarlo en un lugar donde reciba luz directa del sol.
- Mantener siempre húmeda la tierra
- Esperar una o dos semanas dependiendo de la semilla que se utilice (en este ejemplo se utilizó tomate cherry).
- Cuando la planta tenga al menos 4 hojas verdaderas se traslada a una maceta mas grande
- Si germina mas de una semilla por agujero pueden elegir la planta que se desarrolle más rápido y cortar las demás
