Introduction: How to Make a Self-Watering Plant Stand
I have an amazing ability to under or overwater house plants which always ends with the plant dying, so today we’re going to make a plant stand with a hidden self-watering reservoir that allows the plant to regulate how much water it needs and when
Supplies & Materials (Affiliate Links):
· Circle Cutting Jig - https://amzn.to/30DQOaV
· Router - https://amzn.to/3jwr0om
· Palm Sander - https://amzn.to/3d2cFxw
· Total Boat Penetrating Epoxy - https://amzn.to/3d1YSHa
· Total Boat Makerpoxy - https://amzn.to/30CjHnR
· Simple Finish - https://amzn.to/2GEOucn
· Concrete - https://amzn.to/34ZByIq
· Pipes - https://www.supplyhouse.com/sh/control/product/~product_id=BLN050-1000
· Coupling - https://www.supplyhouse.com/sh/control/product/~product_id=FBCO1/2
· 12x12 Piece of Leather - https://amzn.to/2uPYGZJ
· Leather Working Starter Tool Kit - https://amzn.to/2uGPGG7
· Leather Rotary Cutter - https://amzn.to/2uTr1yd
· Inexpensive Mallet - https://amzn.to/3ada6Xv
· Leather Marking Pen - https://amzn.to/30pEEAV
Step 1: Cut the Circle Plant Stand Tops
I started with the plant stand top which will consist of two circle pieces of Sapele glued together with the reservoir cut out in the middle
I wanted to create a very shallow shelf for the planter to sit down in, so I used the pot to trace its diameter
I then used my router and circle cutting jig to cut the outline of the shelf
The circle jig is very easy to do – you simply attach the pivot screw in the center of the circle, align the router bit on the traced circle line, and cut out the outline
Next, I moved on to cutting out the larger of the two circles
The size doesn’t really matter, so I set the circle jig to cut just within the width of the board
To cut all the way through, I had to do multiple passes lowering the router a ¼ inch each pass
I then cut all the way through the center using the same process to create the top portion of the reservoir
Next, I cut the smaller bottom circle the same way, but only cut the center void about halfway
This will become the bottom portion of the reservoir that will hold the water
To give the plant stand top a little shape, I added a round over to the top and bottom of both circles
And then I gave everything a sand up to 320 grit
Step 2: Top Glue Up and Epoxy Sealing
Next, I moved back to my shop to glue the two circles together, making sure to align the center holes
To prevent the wood from absorbing the water, I started by applying a layer of Total Boat’s penetrating epoxy
Once that was dry, I added another layer of Total Boat’s Makerpoxy which is a little thicker
This may have been overkill, but I’m always in the camp of better safe than sorry
While that dried, I moved on to making the concrete base
Step 3: Concrete Base Prep
To connect the stands leg to the concrete base, I incorporated a flange on the top of the base
Using a forstner bit, I cut a hole in the bottom of a bowl so the flange would sit flush to the surface of the base
Then to temporary close the flange opening, I used a combination of nuts and washers
To give the concrete something to grab onto, I superglued some screws into the flange
Next, I used some hot glue to hold the flange in place and make the seam watertight for the concrete pour
I also used some silicone on the inside seam
Step 4: Concrete Pour
Next, I mixed up some Quikrete 5000 to the consistency of oatmeal and poured it into the bowl
To get rid of as many bubbles or blemishes in the concrete, it’s important to poke and vibrate the bowl as you go
After about a day or so, the concrete had cured and was ready to take out of the mold
I wanted to make the base darker, so I wiped on some India Ink
The India ink gives the concrete almost a metallic look sometimes which can be a cool effect
With the base done, I switched back to the top which was ready for finish
Step 5: Adding Finish to the Top
To finish the top, I went with Maker Brand’s Simple Finish w/ Wax which is, as the name would suggest, a super simple finish to apply and leaves a really nice natural finish
You simply wipe it on, wait 15 minutes or so and then wipe off the excess
Step 6: Making It Self-Watering/Self-Regulating
Next, I moved on to attaching another flange to the bottom of the top
Because of the reservoir, I had to use some very shallow screws which I spray painted black to match the ones I used on the base
Ok, now for the self-watering or self-regulating part
The idea is that you insert synthetic strings into the soil of the plant through the hole in the bottom of the pot leaving a couple inches hanging out the bottom which will sit down in the reservoir filled with water
The plant then pulls the water up into the soil as it needs it – thereby eliminating any guessing as to when and how much you need to water the plant
I know it sounds a little crazy, but it totally works. All you need to do is remember to make sure the reservoir has water in it every couple of days
With the top done, we’re ready for the final assembly
Step 7: Final Assembly
I grabbed a ½ inch coupling and a couple of pipes to connect the top to the base, and then simply screwed everything together and it was done…or was it…
Step 8: Post Final Assembly Adjustments – Wrapping the Pipes in Leather
I wasn’t happy with how it looked when I did the final assembly, so I decided to wrap the pipes in leather and make the base a little wider and not dye it.
To add the leather accents to the pipes I started by cutting the leather down to length which ended up being 8 and a half inches
Then I just eyeballed how wide the piece would need to be to completely wrap the pipe
Next, I used my wing divider and some leather pricking irons to add stitching holes to each side of the seam
And then I used the corset stitch to close the seam and wrap the pipe
If you want more details on how to do this stitch and others, I made a video dedicated to leather stitching where I go in depth into the process and I will leave a link here for you to check it out
Step 9: Redoing the Base
I used essentially the same process to make the new wider base, only this time I had a small leak which made the flange a little rusty
But since the rust was really just on the surface, I simply used some Acetone and an old toothbrush to remove it and it worked great
Finally, to protect the floor from getting scratched, I cut a scrap piece of leather to size and glued it to the bottom of the base with some Tandy Leather EcoWeld
After that, all that was left was to swap out the new base for the old one and we’re done!
Thanks so much for following along with this project! I’d love to know what you think. Leave a comment below and don’t forget to watch the video on my channel!
See you on the next project!
