Introduction: How to Make a Solid Double Crochet Spiral Circle
The Crochet Pattern for making a Spiral circle is same as the Common Crochet Circle. The only difference is , the usual Crochet Circle is worked round after round by ending each round with a slip stitch and the Spiral Crochet circles are worked in continues rounds. You can make crochet spirals with a single color, two tone spiral or you can whip up a spiral with multiple colors too.
Few days back I had shared the pattern for making a Solid Two Color Spiral Crochet Circle. Here is a simple pattern for Solid Double Crochet Spiral Circle with only one color of yarn. The pattern is very simple which lays flat with no gapping holes. It is worked in continuous round with no visible seam.
You can use this spiral pattern to make up crochet potholders , Crocheted rugs ,Crochet hats and Placemats. Just keep making the increase pattern untill the size of your choice.
Note:-
- The circle is made in continuous rounds , i.e. we wont be making a slip stitch at the end of every round.
Visit https://rajiscrafthobby.blogspot.com/2022/08/how-to-make-solid-double-crochet-spiral.html
8 Ply Yarn
4 mm Crochet Hook
Step 1:
Here is the Video Tutorial:-
You can follow along with this tutorial video. Please be sure to subscribe too!
Step 2:
Round 1:-
Start with a Magic Circle.
12 Double Crochets in the circle.
Pull the yarn end to close the gap.
We will be working in continuous rounds.
12 Stitches.
Step 3:
Round 2:-
2 Double Crochets in each stitch around.
Keep a track of the stitches with a stitch marker.
24 stitches.
Step 4:
Round 3:-
1 Double Crochet.
2 Double Crochets in the next stitch.
Repeat*(1DC, 2DC).
36 Stitches.
Step 5:
Round 4:-
1 Double Crochet each in 2 stitches.
Repeat*(1DC*2, 2DC)
48 Stitches.
Step 6:
Round 5:-
1 Double Crochet each in 3 stitches.
Repeat*(1DC*3 2DC)
60 Stitches.
If you wish to continue making it larger, then follow the below mentioned increase pattern:-
Round 6--DC 4, 2DC in next stitch(72)
Round 7--DC 5, 2DC in next stitch(84)
Round 8--DC 6, 2DC in next stitch(96)
.....and so on.
Step 7:
Ending:-
If you weave off the spiral circle, It would look unfinished. So to tapper it down , finish it off with the below stitches:-
1 Double Crochet each in 2 stitches,
1 Half Double Crochet each in the next 2 stitches,
1 Single Crochet each in the next 2 stitches,
1 Slip Stitch each in the next 2 stitches and weave off.
