Introduction: How to Make a Spiral Potato Cutter at Home || DIY Spiral Potato Slicer
Have you ever wanted to make your own spiral potato slicer at home? Well, you're in luck! In this tutorial, we'll guide you through the process of creating a DIY spiral potato cutter using a reused tin can and some basic tools.
Prepare Your Materials:
- Reused tin can
- Plastic bottle
- Plastic bottle cap
- Piece of wire
- 2 screws
- Hot glue gun
Step 1: Mark and Cut the Tin Can
Join us as we demonstrate each step in detail!
Using a marker, make two marks on the bottom of the tin can. Then, drill two holes at these marks. Connect the holes with a line and cut along this line with Dremel.
We will sharpen the bottom cut well, to cut the potato easily.
Step 2: Prepare the Plastic Bottle
Cut off the bottom of the plastic bottle. This will serve as an extension for the tin can.
Step 3: Prepare the Bottle Cap
Drill three holes in the plastic bottle cap. Insert the wire through the middle hole (which will hold the potato), Insert screws through the other two holes (which will hold the potato) and secure them with hot glue.
Step 4: Enjoy Your Spiral Potato Delights
Once you've spiral-cut your potatoes, you can fry them to make delicious spiral potato chips or season them for a tasty snack. They're perfect for parties, gatherings, or just a fun snack at home!
