Introduction: How to Make a Attack Type Beyblade/Top (With Lego!)
Hello there. If you are reading this, it's probably because you want to know how to make an attack-type Beyblade. Well, this is the perfect Instructable for it!
All the supplies you will need are listed here:
1 axle
1 big wheel
1 of those things that will hold the wheel in place (with an axel attachment on the center)
1 smallish bolt that can LOOSELY fit in the axel (for the attack)
1 circular 4x4 plate
3 circular 2x2 plate
1 of the 2x2 circular thing with a curved bottom
1 4x4 circular thing with 4 spikes
1 circular brick
1 circular bolt for the axle
Step 1: The Spike
Add the spikey part on top of the 4x4 circle. Set aside.
Step 2: Making the Base
Get 2 of the 2x2 circle, put them together, then put them on top of "The Spike." Then get another 2x2 circle and put the curved 2x2 part on it, then put it under The Updated Spike.
Step 3: The Bolt
Get the axel and the bolt, and push the axel to the Base (But don't push it all the way through! Just let it touch the bottom). Then get the two-wheel parts and put them together. After you do that, put the circular bolt for the axel on top of that (just at the edge of the axel).
Step 4: The Finished Product
Now, push the wheel (the dipped part to the bottom) all the way through so it fits snugly, then put the 2x2 circle on top of that. Now enjoy your new attack type! (The loose bolt on the inside will off balance it and then the bottom will do an uppercut kind of thing, the rubber is also good at spin stealing/attacking, and will spin for about 45 seconds if built correctly!)
