Introduction: How to Make a Stomachion Archimedes Puzzle
The Stomachion, or Ostomachion as pointed out by the Ancient Roman poet Ausonius, was a puzzle game from the Ancient Greek, similar to the Chinese Tangram.
The original game was made of 14 pieces made of bone. The Ancient Greek Archimedes studied the game and wrote a mathematical treatise about its geometric and combinatorial properties, known as the Archimedes Palimpsest. Little is known about the rules of the game. It seems that Archimedes used it as a combinatorial test asking how many different arrangements of the puzzle are possible.
Attached is the fusion 360 files and the stl version
If you don't have fusion 360 you can get for free if you are a student/ hobbyist or an educator.
This is my first instructsabels
Component1.f3d
Component10.f3d
Component11.f3d
Component12.f3d
Component13.f3d
Component14.f3d
Component15.f3d
Component16.f3d
Component17.f3d
Component18.f3d
Component2.f3d
Component3.f3d
Component4.f3d
Component5.f3d
Component6.f3d
Component7.f3d
Component8.f3d
Component9.f3d
Component21.f3d
Component22.f3d
Component19.f3d
Component20.f3d
Component24.f3d
Component23.f3d
stomachion-archimedes-puzzle v5.f3d
stomachion-archimedes-puzzle v4.stl
Fusion 360 or any other 3d modeling software.
Step 1: Part 1 : Create the Frame
- Draw a square 15.24 cm by 15.24cm
- Extrude the shape by 2 mm
- Shell the shape by 5mm to the outside
- You should get something similar to mine
Step 2: Part 2 : Creating the Pieces
- Start by drawing a shape then extruding it by 2mm
- Make sure to select new component when extruding the shape as it would be easier to export it as an stl file to 3d print
- if you are not sure then you can have a look at my example above.
- repeat the the steps in part 2 for the remaining pieces.
Step 3: Part 3 - Add Colours
once you are done you could add colour or send it off to the 3d printer and print it
