Introduction: How to Make a Swamp Wood Flickering LED Table Light DIY
Materials & tools:
piece of swampwood
piece of beech
piece of leather
3 orange flickering LED
power adapter
mini switch
resistor
dc socket
shrinking tube
wire
screw
solder
cardboard
pencil
scissor
jigsaw
sandpaper
clear epoxy resin
tape
4mm, 5mm, 10mm drill
forstner drill
wood wax
2 components filler
glue
lighter
Step 1: Preparation
Mark the stand from the swampwood on cardboard and mark a again with a little space. Cut the cardboard and mark the baseplate on a piece of beech. Remove the edge from card cardboeard and mark the base again. Saw the baseplate out. Round the edges of the top to the mark. Coat the swampwood twice with clear epoxy resin. Cover the base with tape and mark the stand. Mark where you want to have the lightning. Drill 4mm holes for the LED.
Step 2: The Electronic
Mark the place for the electronics and drill space with a forstner drill. Drill the holes for the switch & dc plug. Give the wood a wax polish. Solder the elektronics and check if everything works. Drill a hole through the base and in the swampwood. Screw the base and the swampwood together. Fill the underside with 2 components filler and smooth it.
Step 3: Finish
Mark the stand on a piece of leather and cut it out with a scissor. Glue the piece under the base and flame carefully the edges with a lighter. Plug it in, turn the switch and enjoy.
Look at my other work.
