Introduction: How to Make a Tassel Using a Book and Wool
These instructions will show you how to make an easy tassel.
Step 1: Get Your Supplies and Start Your Tassel
Things you will need: a book, wool, and scissors.
Take the book, then undo the wool a little bit to separate from the wool.
Step 2: Wrapping Wool Around Book
Place end piece of wool on bottom of open edge of the book, hold it in place and wrap wool around 30 times.
Step 3: Now Make a Tail
Then undo an extra 20 cm of wool to have a tail which will over hang from the open edge of the book.
Step 4: Now Weave Another 20 Cm of Wool
Now cut another 20 cm of wool from the ball and weave through the wool on the front of the book and then slide wool down to the spine of book and tie in a triple knot.
Step 5: Then Take the Scissors
Then take the scissors and cut wool on far right side of book where the book opens opposite to where you tied the triple knot.
Step 6: Cut Another 20 Cm of Wool
Then fold over wool until it looks like an octopus then cut another 20 cm of wool from the ball of wool.
Step 7: Wrap Around Wool
Wrap around wool in a triple knot about 2-3 cm from top of wool.
Step 8: Then Shorten
Then shorten the long bits of wool to make it all even with the shorter bits of wool using the scissors .
Step 9: Finished
Now your tassel is finished.
