Introduction: How to Make a Thermal Sensing Oven Mitt
This Instructable will teach you how to make a thermal sensing oven mitt.
Step 1: Items to Acquire
Items Used:
Digital Thermometer
Oven Mitt
Hot Glue Gun
Diamond Tipped Files
Spare Wire
Step 2: Cut Metal Tubing
Use file to cut the tubing, be sure not to damage the wire. Leave tip intact as it will be used later.
Step 3: Disassemble Thermometer
Twist the case use file or screwdriver to ply open the case. Be sure not to damage the board. Pull wire out of back side of casing.
Step 4: Glue Metal Tip to Sensor
Be sure not to cover sensor in the glue.
Step 5: Cut Slit in the Stitching of the Mitt
Shove the extra wire through the end.
Step 6: Glue Wire to Sensor End and Pull Through
Hot glue the Sensor into position after.
Step 7: Glue the Screen to the Mitt
And you are done.
Wearable Tech Contest
2 Discussions
5 years ago
Umm... excuse my probably silly question here: What's this for?
Thanks!
5 years ago
Really simple idea and execution! Thanks for sharing and welcome to instructables!
