Introduction: How to Make a Touch☝ Sensor Circuit Using Transistors on Breadboard☝
In this tutorial I'm gonna teach you how to make a simple touch sensor Circuit with transistors. I basically uses my finger as a resister to give a signal to Bace of the transistor and light up the LED. You can also replace the LED for a buzzer or any other output component if you wish.
Step 1: Part List
* Breadboard
* LED (any colour)
* Transistor (D200) - 2X
* 220Ω Resistor
* Connecting wire
* 9V Battery
Step 2: Connect Transistor C Pins Together
Step 3: Connet Transistor 1 B Pin With Transistor 2 C Pin
Step 4: Connect Transistor 1 E Pin to the Ground
Step 5: Connect Transistor 2 C Pin to LED
Connect Transistor 2 C pin to LED cathode and Connect anode it to positive using a 220Ω resistor
Step 6: Connect the Touch Pads
You can use two connectors as touch pads if you want .Connect one pad To Transistor 2 B pin And the other to the anode of the LED.
