Introduction: How to Make a Undertale Animation on Scratch
I want people to know how to make a undertale animation for fun in scratch.
you need sprites and sprites.
Step 1: First Head
Crop the head out of the sprite sheet then copy it to a new sprite then add a when flag clicked then add a go
to block and then add a when flag clicked and add a point in direction 90 block then make a show block and add a set size to any size add the variable above then add a forever block and add a set x block and make a variable called x then add a - block and put x in the front and 10 in the back then add a set y block and make a variable called y and add a + block and put a * block in the back and the variable y in the front. Add a + block then put 3 in the front. Add a - block then add a 9 in the front and add the sin of block then make a variable called timer and add a * block add the timer front and add a 12 in the back. The. Add a turn ( block. Add a + block then put any number in the front and add a * block and add 3 in the back after add a - block then add a cos of block and add the variable *** in the front and 8 in the back. Add a sin of block and add the variable *** in the front and 12 in the back. After add a change *** variable by 2 and a change timer variable by one. Also add a when flag clicked put set x variable to 12 and a timer variable to 0 and the variable y to ten. If you do all that it should look like the picture above.
Step 2: Body
First add a when flag clicked block and add the go to block then add another when flag clicked block and add a set size block add a forever block and a set y block .
After put a + block and add a x position of your leg sprite block in the front then add a * block in the back and put 5 in the back of the * block then add a sin of block.
then add a * block and put 10 at the back and create a new variable and name it sin then add the variable sin in the front of the * block.
Step 3: Leg
The leg does not need to move you can make it move if you want.
Step 4: Bonus
Copy the code cuz I’m lazy lemme know in the comments if you can’t see them
Step 5: Extra
You can add music and other stuff to it(Byee)
