Introduction: How to Make a Vacuum Cleaner by Yourself?
The self-madevacuum cleaner is based on Bernoulli's principle: the fan blades rotate to drive the air inside to flow quickly. The fast-flowing wind produces low air pressure. The air pressure inside is small and the air pressure outside is high, so small objects are sucked in.
Step 1: Prepare the Required Materials
Small wooden square, propeller, battery box, AAA battery, small motor, gauze, screw, small switch, glue, double-sided tape, rubber band, etc.
Step 2: Make the Bracket
Fix the motor card position and bracket with screws
Step 3: Glue the Battery Box and Small Motor
In this step, we need to glue the battery box and the small motor well, we can use a good glue to glue it, we must stick it firmly.
Step 4: Install the Propeller and Connect the Wires
The same is true for this step, we have to make sure that each part is installed firmly.
Step 5: Fix the Gauze on the Mineral Water Bottle
Cut off the bottom of the mineral water bottle, and fix the gauze on the mineral water bottle.
