Introduction: How to Make a Vanilla Robot Cake
ingredients
Cake:
- 3 cups (450 g) unbleached all-purpose flour
- 1 tbsp baking powder
- 1/2 tsp (2.5 ml) salt
- 4 eggs
- 2 cups (420 g) sugar
- 1 tbsp (15 ml) vanilla extract
- 3/4 cup (180 ml) canola oil
- 1 1/4 cup (310 ml) milk
Icing:
- 3 cups (720 g) of icing sugar
- 1 tsp (5 ml) vanilla extract
- 1/2 cups (120 ml) butter (softened)
- 1/4 (60 ml) milk
(EVERYTHING MULTIPLED BY 2 FOR THE 2 CAKES)
Supplies:
- measuring utensils
- hand mixer whisk
- 3 large bowls
- rectangle (40cm x 20cm) baking dish
- piping bag
- knife
This is how you bake and decorate a vanilla robot shaped cake.
Preparation 35 min
Cooking 55 min
Servings 12
Freezes Yes
Step 1: Oven Preheat
The first thing you should do is preheat the oven. This is so that as soon as you are done making your cake batter you can put it straight into the oven
Step 2: Mesuring
Gather all the tools you will need to bake this cake ( measuring spoons/cups, mixing spoon, baking tray).
Step 3: Dry Ingredients
In a large bowl combine the flour, baking powder, and salt, give the dry ingredients a little stir then set the bowl aside.
Step 4: Wet Ingredients
In another large bowl beat the eggs, sugar, and vanilla with an electric mixer for 10 minutes or until the batter gets thick. it should also turn into a pale color and should be triple the volume while you are beating the batter, then drizzle in oil.
Step 5: Mixing
At a low speed, add the dry ingredients with the wet ingredients until it is perfectly smooth (there should be no dry clumps). Divide the batter into 2 pans so your cake is evenly cooked when its done.
Step 6: Baking
Place your cake batter in the oven and bake for 50-55 five minutes. To make sure its cooked grab a tooth pick, insert it into the middle of the cake, if there is no raw batter stuck to the toothpick then you can take the cake out.
Step 7: Cooling
Let it cool for about 25 minutes, after 25 minutes you can take the cake out of the pan and place it on a large piece of cardboard (to be easily transportable).
Step 8: Making the Icing
While waiting for your cake to cool you can make your icing, mix your butter, icing sugar, vanilla, and milk. Beat with a hand mixer until smooth and icing like. Separate your icing into as many different colors as you want and use food dye to make them different colors (we did pink, and white).
Step 9: Shaping the Cakes
Your going to need to cut your cakes into different shapes for the robot.
- 1 square (10cm x 10cm) for the head
- 1 smaller rectangle (3cm x 6cm) for the neck
- 1 large rectangle (20cm x 17cm) for the body
- 2 long rectangles (14cm x 4cm) for the legs
- 2 rectangles (11cm x 3cm) for the arms with cut slant where it touches the body
- 3 small half circles for the head details
Step 10: Icing the Cakes
Now that everything is prepared you can start decorating!
