Introduction: How to Make a Vocal Booth for Recording Vocals at Home
vocal booth at home is the best way to start your career as a singer or voice talent. I have created a soundproofed vocal booth in my room, and the results are amazing.
Creating a vocal booth at home can be a rewarding project, and here's a step-by-step guide to help you set it up:
Tips:
- Consider using bass traps in the corners to control low-frequency sound.
- Experiment with the placement of acoustic panels to find the most effective configuration.
- I have installed the exhaust fan that helps in circulating fresh air from outside.
Remember, the success of your vocal booth depends on proper planning and attention to detail. Adjustments may be needed based on the specific acoustics of your space.
Materials Needed:
1. Frame Material: PVC pipes or wooden studs
I have used wooden studs
2. Panel Material: Acoustic foam panels or blankets ,Rockwool
3. Fabric: Breathable fabric or moving blankets
4. Adhesive: Spray adhesive or velcro strips
5. Fasteners: Screws, nuts, and bolts
6. Tools: Saw, drill, screwdriver, measuring tape
Step 1: Design and Planning
- Decide on the size of your vocal booth based on available space 6x4x6, 6x6x6, 8x7x7
- Plan the frame structure, ensuring it is sturdy and can accommodate acoustic treatment.
Step 2: Build the Frame
Build the Frame
- Cut the PVC pipes or wooden studs to the desired lengths for the frame.
- Assemble the frame, securing the joints with screws or nuts and bolts.
- Ensure the frame is stable and square.
Step 3: Cover the Frame
- Attach the fabric or moving blankets to the frame using a staple gun or adhesive.
- Fill the rock wool slabs with at least 80mm or 100mm density, leaving an inch gap between the rock wool slab and the adjacent wall.
- Make sure to cover all sides, leaving an opening for the entrance.
Step 4: Add Acoustic Treatment
- Apply acoustic foam panels to the interior of the booth.
- Place panels strategically to absorb sound reflections and reduce echo.
Step 5: Seal Gaps
- Check for any gaps or openings in the booth,install door seal on the gaps when the door is closed.
- Seal gaps using additional fabric, weather stripping, or acoustic caulk to prevent sound leakage.
Step 6: Create a Door
- If you want a door, attach a fabric or moving blanket using hinges.
- you may use mall-loaded vinyl for the best sealing of the outside noise.
- Ensure the door closes securely to maintain sound isolation.
- Install the door seal in the gaps to cut down the external noise.
Step 7: Set Up Inside
- Add any necessary equipment, such as a microphone stand, pop filter, and a comfortable chair.
- Test the acoustics and make adjustments as needed.
Step 8: Test and Adjust
- Record some audio inside the booth to assess the sound quality.
- Make adjustments to the acoustic treatment if necessary.
- Voice Samples recorded in a booth
Step 9: Final Finishing(optional)
I have cut down the green grass rug into a section of 3x2" slabs and pasted it with heat-proof adhesive for the firm griping of the rug on the vocal booth.
I am devoted about how to improve sound quality and voice over recording, It helps voice over artist, to build their own vocal booth.
