Introduction: How to Make a Water Level Alarm With Nano Board
Nowadays water tank has been widely used to store water for department. But there is one problem, how can we know there is no water or the bumping water overflows in time? It’s real inconvenient to check the state again and again. With some programming knowledge, I decide make this alarm to inform with beeping and light indicator. This can be applied to some water level invisible tank or tower.
Have a try!
Step 1: Prepare Materials
SunFounder Nano board - http://bit.ly/2fwJNnj
USB cable
Some jumper wires - http://bit.ly/2tXqPZN
4 LEDs (white, green, yellow, red)
Passive buzzer
Plastic bottle
Foam board
Drinking straw
Dielectric stick
Scissors
Electrical Tape
Color Pen
Step 2: Make a Water Tank
Stab at the bottom of the bottle to get a hole, then thread the drinking stick across the hole, and seal with glue.
Step 3: Make Water Level Probe
Fasten a jumper wire’s one end to the bottom of the stick and the other end to +5V power. Fasten the four other wires evenly on the stick in the same way. (Adjust the interval distance according to your actual needs)
Step 4: Insert the LEDs and Buzzer
Draw a whale (whatever other image you like) on a paper and paint with color, then paste this paper on the foam board. Insert the buzzer to the whale’s eye position, and four LED to the spout position in order. (Insert those components’ pins across the foam board, thus the wiring in later part will be easier.)
Step 5: Wiring
Complete the wiring as shown:
Step 6: Upload the Code
#define uchar unsigned char
uchar flag = 4;
void setup()
Serial.begin(9600); // start serial port at 9600 bps:
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
void loop()
int w = analogRead(A0); //read the value from analog pin AO
int g = analogRead(A1);
int y = analogRead(A2);
int r = analogRead(A3);
Serial.println("w:");
Serial.println(w);
Serial.println("g:");
Serial.println(g);
Serial.println("y:");
Serial.println(y);
Serial.println("r:");
Serial.println(r);
if((w< 1000) && (g > 1000) && (y > 1000) && (r > 1000)) //Stop when the car is picked up
flag = 0;
else if ((w< 1000) && (g < 1000) && (y > 1000) && (r > 1000)) //if read the value of the Tracking module data[0] is more than 100
flag = 1;
else if((w< 1000) && (g < 1000) && (y < 1000) && (r > 1000)) //if read the value of the Tracking module data[2] is more than 100
flag = 2;
else if((w< 1000) && (g < 1000) && (y > 1000) && r< 1000) //if read the value of the Tracking module data[4] is more than 100
flag = 3;
else
flag = 4;
switch(flag) //According to the relative position of the line and the car, adjust the front wheel steering angle to change the direction of the car to achieve inspection line.
case 0:
digitalWrite(2,HIGH);
digitalWrite(3, LOW);
digitalWrite(4, LOW);
digitalWrite(5, LOW);
break;
case 1:
digitalWrite(3,HIGH);
digitalWrite(2, LOW);
break;
case 2:
digitalWrite(4,HIGH);//turn the LED on
pinMode(9, OUTPUT); //set the pin 9 as an output
tone(9, 3000, 100);
delay(400);
tone(9, 0, 10);
delay(400);
pinMode(9, INPUT); //set the pin 9 as an input
break;
case 3:
digitalWrite(5,HIGH);
pinMode(9, OUTPUT);
tone(9, 3000, 100);
delay(80);
tone(9, 0, 10);
delay(80);
pinMode(9, INPUT);
break;
case 4:
break;
Step 7: Put the Stick in Water Tank
Step 8: Water Level Indicator Done!
Clog the drinking straw on the tank, and add water to the tank until the water reaches the topmost probe.
Release the clogging, then observe the water level and the LED.
