Introduction: How to Make a Waterblock
This is n instructable on how to make a waterblock. It can be used for whatever you want. I'm using mine for a TEC which I have various projects I will cool with it. You could also use it for cooling your processor.
Step 1: Materials and Tools
Materials:
JB Weld
Aluminum bar
or
Copper and solder, aswell as a blowtorch.
Hose barbs- if you use copper you can use brass or plastic barbs
- if you use aluminum you can use aluminum or plastic hose barbs.
-plastic ones can be cheaply found in the plumbing and garden section. Instead of buying the white nylon ones you can use the cheap plastic abs ones. Mine are toro. I only used a nylon one because I had it on hand.
You can't use aluminum in the same system as copper or any less reactive metal because the aluminum will corrod due to the electrical potenetial between the elements.
Tools:
Drill
Drill Bits
Center punch
Hammer
Vise
Powdercoat System
Glow ind the dark powder coat paint
I used this in addition to my blue:
http://www.caswellplating.com/powder/additives.html
Metal Cutting Bandsaw
Belt Sander
JB Weld
Aluminum bar
or
Tools:
Drill
Drill Bits
Center punch
Hammer
Vise
Powdercoat System
Belt Sander
Step 2: Mark Out Your Pattern
Make a pattern for you to follow for drilling. Be careful with your spacing, making sure they are far enogh from eachother so that when you are drilling you don't slip from one hole to the other.
If you printed it out glue it on to the metal with rubber cement.
Use your center punch to punch a spot in the center of each hole so that you know where to drill.
You can use a nail as a centerpunch.
Step 3: Drill Out the Holes
Use your drill to drill out holes, following the pattern.
I used a lathe for some parts and a drill for others.
If you have a drill press you can use that.
Step 4: Prepare for Bonding the Base to the Top
Sand the top surface of the base to remove any burrs that might interfere with bonding.
If you use a belt sander I recommend you use a lubricant to sand. The aluminum can clog the sandpaper without a lubricant.
I used WD40.
Cut out a piece of metal for the top. Sand it before bonding.
I used WD40.
Step 5: Attaching the Lid to the Base
If you use JB Weld, mix it on a seperate platter and put a small bit around the circumference of the block, press it on and clamp it.
If soldering clean and sand the surface. Flux it. And heat up and solder.
If you are using copper ou can use brass hosebarbs and solder them in.
Afterwards drill holes in the lid for the hose barbs to go into.
Step 6:
Sand down the edges and all sides.
Lap the base with increasingly fine sandpaper. I didn't do this step. I stayed with course sandpaper and just lubricated it which made it cut much smoother.
Step 7: Paint
Degrease the entire block. Place the block on a piece of paper. Put a wire into the block and attach it into the ground for the powdercoat line. Spray it and place it in the oven. Follow the settings for your powdercoat.
For mine its was 20 minutes at 400 degrees farhenheit.
Step 8: Attach Hose Barbs
Cut the hosebarbs down to size.
Jb weld the hosebarbs into the body.
If you have extra jbweld on the barrbs, use wet q-tips to wipe the extra jbweld off.
