Introduction: How to Make a Wind Turbine Using Wooden Propeller
About: Hi Friends, Follow me for more Physics related projects.. I'm a renewable energy passionate. Join me, Have FUN
Let’s make a DIY horizontal axis wind turbine project using a real wooden propeller. I have already created two horizontal and two vertical axis wind turbine projects for the New Physicist. You can find those tutorials on this blog by searching ‘DIY wind turbine’.
Read Full Article here DIY Wind Turbine
  • 1 meter Long/2.5″ width/ 1″ dia
  • Wood Pieces 3 Nos
  • Supporting Wood pieces for tail and hub
  • GI Pipes in Required length
  • Geared DC motor as Dynamo
  • Other Foundational Requirements
  • You need an Angle grinder/sander
  • Wood/Metal Cutting Tools, both hand and Powered
  • Welding Machine and other Necessary Tools
  • Drill and all required Drill bits
  • Paint,
  • sanding paper and Brushes
Step 1: Fixing Blades Together
A wind turbine propeller blade as an aerofoil cross-section. Refer to the second image. We have to carve an aerofoil from the wood pieces. Three such aerofoil blades are needed to make a wind turbine.
Step 2: Dynamo, Gear Box, and Tail
The homemade wind turbine propeller is ready. I suggest you use teak wood. So that you can easily sand them and carve the required shape. The most important and tricky part of a wind turbine is its propeller. Rest is a piece of cake. Make sure each blade weighs the same. Unless they are equal we cannot balance the propeller perfectly. Any imbalance caused by weight difference will lead to a drop in performance.
