Introduction: How to Make a Windmill House Model
About: Laser professor
Let’s make a laser cutting windmill house model as inspiring and innovative as you are! Laser cutting transforms plywood into an intricate masterpiece, ensuring your model stands out in maker spaces and classrooms while sparking creativity and learning.
Ready to give your projects the creative edge they deserve? Follow the steps below and cut your way to success with the windmill house model!
Machine Used
Thunder Bolt 30W
Material Needed
3mm plywood
Engraving
  1. Speed:1000mm/s
  2. Power:45%
  3. DPI:254
Cutting
  1. Speed:5mm/s
  2. Max Power:80%
  3. Min Power:10%
Step 1: Place Your Plywood for Laser Cutting
Before your work begins
  1. Verify the lens is clean or there's no problem in the laser.
  2. Make sure the exhaust fan is working well.
  3. Ensure the air assist is on.
Choose a flat plywood board on the laser honeycomb bed.
windmill house model material
Step 2: Open the Model File and Check the Laser Plywood Settings
Check out the design is important. Since there are a lot of parts, don’t miss anyone! And ensure that the parameters are set correctly to achieve the ideal laser cutting windmill house model. In addition, laser compensation is to be set.
If the min power is too low, it will cause the stroking corners will be too shallow and the cutting corners will not cut through; if the min power is too high, it will cause the stroking to cut through the corners and the laser cutting will be bad at the corners.
windmill house model setting
Step 3: Focus on the Plywood
Without focusing, your outcomes may fall short of expectations. So before starting, make sure you’ve rightly focused.
For focusing, you have two options: Auto Focus, which is simple—just press the AF button on the Thunder Bolt screen. Then you’re ready to have a laser cutting.
auto focus
Step 4: Frame the Model Design and Start Laser Cutting
When you click “Frame”, the red light will display the laser cutting area. This is a safe process, and the frame will align with the plywood. Once aligned, simply press “Start” to begin the plywood laser cutting with the Thunder Bolt!
laser world map 3
Step 5: Monitor the Laser Cutting Process
To avoid any issues, carefully monitor the laser cutting, especially when unusual conditions like alarms arise.
Considering the laser cutting energy, for safety reasons, we advise against staring directly at the process, even with the laser door closed.
Step 6: Assemble the Windmill House Model
When the laser cutting plywood is completed, it’s time to get it out. Then it’s just a fun assembly time to get the ideal windmill house model. Imagine the joy of assembling the model, as each piece clicks into place to create a beautiful, layered home decoration.
When assembling complex models, following the sequence from bottom to top and inside to outside makes it easy and quick to complete the assembly. Another tip is modular assembly. For example, we can assemble the base, windmill, house, and ladder separately, and then put them together quickly!
windmill of windmill house model design
assemble windmill of windmill house model (2)
assemble windmill of windmill house model (1)
assemble windmill of windmill house model (3)
assemble windmill of windmill house model (4)
Assemble the House
house of windmill house model design
assemble house of windmill house model
assemble house of windmill house model 2
Assemble the Other Parts
assemble windmill house model 2
Come and Try!
Laser cutting windmill house model is designed to inspire hands-on learning and spark innovative ideas. Its elegant design serves as a functional educational tool, and transforms any space into a vibrant workshop of imagination.
Ideal for creative projects, collaborative learning, and engaging demonstrations, the windmill house model is more than just a model. It’s also an invitation to explore, experiment, and elevate the art of laser cutting.
assemble windmill house model done
