Introduction: How to Make a Wooden Shield With a Poly Finish
This is a fairly good shield for decoration and could be used for mild defense.
You want to have at 1 48 inches long, 16.5 inches wide, and .77 inches deep plank or 2 boards of half the length and width.
You want both Minwax golden pecan 245 and Minwax honey 272.
You want a hand sander and 120, 180, and 240 grit sand paper.
Steel wool after the first layer of poly
Zar Classic clear poly
Step 1: Making the Plans
For this step I used fusion 360 to make a 3-D model of the shield and Easel to make the pattern to be engraved on the shield.
Step 2: Finding the Wood.
For the wood I used pinewood. The wood I used 2 planks 8.25 inches wide 24 inches long and .77 inches deep.
Step 3: Cutting the Corners
I used a program in fusion 360 know as shaper origin to get the x-carver cut out the dimensions specified in the model onto the board causing me to get two halves of the shield.
Step 4: Sanding the Board
For this I used 120 grit sandpaper then 180 grit and lastly 240 grit sandpaper. I used a sanding block for the sides that would connect later on.
Step 5: Engraving the Board
I used the x carver to engrave a design .05 inches into the shield. The two designs are put on different halves of the shield.
Step 6: Staining the Board
For this step I used both Minwax golden pecan 245 and Minwax honey 272. I used an old cloth to apply a layer of the honey stain on the engraving and then wiped it off with another clean cloth. After that I applied a layer of golden pecan 245 to every side avoiding the engraving.
Step 7: Gluing the Board
For this step I used 3 briquettes between the two halves of the shield then used 5 clamps to keep the boards together.
Step 8: Apply the 1st Layer of Poly
I used a brush to apply a layer of poly and left it for a day. Afterwards I used steel wool to remove the rough texture that the poly gave the shield.
Step 9: Apply the 2nd Layer of Poly
I used a coating of poly to the front of the shield to give the shield a finish that also protects it.
