Introduction: How to Make a Wreath Out of a Tree Branch
Here's a Christmas wreath I made out of a Juniper tree branch.
I learned something from making this: Don't ever make anything out of these branches, they have annoying little ultra-sharp pokey things all over them, like a rose bush. So, if you do decide that you want to make a wreath out of a Juniper tree branch, wear gloves and do it outside, unless you want to have the pokey sharp things all over your hands and floor.
You'll need:
Normal scissors
Pruning shears
String
Optional, if you want decorations:
Yarn or ribbon
Pipe cleaners/chenille stems
Pom-poms or beads or something similar, if you put these on, you'll need glue.
Lights (weave these around the wreath)
Step 1: Finding the Right Tree Branch
Preferably a pine tree (Pictured is a Juniper tree). The best branch should be long enough and bendy, with plenty of leaves/needles.
Step 2: Making the Wreath
Cut a piece of string, about 6 inches or a little less. Take your tree branch and carefully bend it into a circle shape, then use the string to tie the ends of the branch together, making your wreath. You can also use that sting you tied and make a loop to hang it (pictured above).
Step 3: Finishing the Wreath
The branch might have little branches on it that stick out. Just weave them into the branch.
Step 4: Decorating (optional)
Take the yarn/ribbon and tie it into a bow on the wreath, you might have to glue it. Take the pipe cleaners/chenille stems and cut them into 2 inch pieces and put them on, twisting them so they'll stay (They can also be used to make bows). Pom-poms can be glued on.
