How to Make a Small Gas Furnace
Intro: How to Make a Small Gas Furnace
Why is it that all the things i make involving heat are small?
There's the coal forge, that was fairly diminutive, but i digress.
by-tor the snow dog asked me if the coal forge got hot enough to do glasswork. ( https://www.instructables.com/id/EG8B14NNJJEYMW0DC9/#CEXLBVSRGSWEZ7BDCQJ ) Basically, it does, but i wouldn't recommend it, because the hot coals will stick to the glass ans it'd be manky, so i decided to make a clean, hot-burning furnace using what i had lying around.
STEP 1: Get the Stuff
The first step is, as always, get the things you'll need.
I used the Refractory glop i sued for the coal forge -i'll keep using this until i find something better, IF i find something better- and a can. The can should hold about half a kilo and, even with the refractory taking up some of the space my torch was still struglling to heat all of it up, so if you want a bigger hotspot, you'll need a bigger can,obviously, and more torches for the heat, but that presents some new problems because you don't want the torches to overheat one another. This can held 540 grams of grapefruit. Because the can has to be emptied first, choose something you'd like to eat. If it's beans, work outside.
STEP 2: Make a Hole in the Can
The can needs a hole, through which goes a pipe, into which is inserted the blowtorch. This is a bit like the blast pipe for the coal forge, but instead of blowing air through to fuel a fire, this is where the heat comes from. a chisel and some pliers are all you really need, the hole doesn't have to be precise, just big enough to fit a bit of pipe in. (don't use glavanised steel) Once you've made the hole, cut a length of tube or pipe about 2 inches long. Under no circumstances should the tube obstruct the torch's air holes. If this happens, the fuel mixture will burn too rich and you'll get crabon monoxide poisoning instead of heat. The effects of carbon monoxide are cumulative, each does gets piled on top of the last. The pipe should protrude about half an inch into the can, offset from the top by about 30 degrees. The picture should hepl you determine what it needs to look like.
STEP 3: Add the Refractory
This is the easiest step, though it needs you to get your hands dirty. Using a spoon or a knife or your fingers, coat the inside of the can with refractory. Make it fairly smooth, too, this will make sure there are no nasty eddies or swirls inside the can that can do unpredictable things. The refractory should be between 1/4 and 1/2 inches thick. Mine was somewhere between those. Don't obstruct the pipe!
STEP 4: Some Quick Notes
For those people who can't get XL refractory clay, there are others, more available and less available. The cheapest one i can think of is Adobe. This is simply a 50-50 mix of sand and clay. (no pebbles or rocks) Mix the sand and clay and apply them immediately, then let them dry completely before firing the adobe. After it's been fired once, it's ready for use.
Anyone living near a ceramic supply house or brickyard should be able to find something that'll do the job.
STEP 5: Fire It Up
Once the refractory's ready to be used, use it. As with the coal forge i posted, i recommend that you fire it up without doind any work at least once, just to get a feel for it. Place the torch into the pipe making sure that the burner head of the torch doesn't protrude into the main area of the furnace. For god's sake don't obstruct the airholes. Also, don't even USE your torch if it's in anything other than perfect working order. To light the torch in the furnace, turn on the gas slowly while holding a burning stick, or a bit of rolled up paper with the end on fire in front of the burner. Once it catches, wait a minute or two till it gets up to working tempertaure.
STEP 6: Making Stuff
My thanks to Larry Zoeller, of Zoeller forge for giving me the idea for this. The link leads to a similar one he made that geve me the idea to make this.
http://www.zoellerforge.com/coffee.html
This furnace was designed and made with glassworking in mind, it's like one of the furnaces i used when i went to The World of Glass in St Helens to try glassblowing. There's no reason not to make small forged items in it, though, like arrowheads, but that might necessitate some small adaptations. There's no question about it getting hot enough, certainly.
81 Comments
lemonie 17 years ago
ShonaO1 8 years ago
It does indeed matter, and it is a very good question for those who don't know.
Now, you need to buy a particular type of sand if making refractory clay yourselves. But, the good news is that it is super cheap, so much so I have seen it for sale in "Poundland" for 5kg bags for the princely sum of £1 :-) It is sold as children's play sand. It is kiln dried sand. Do not buy the anything else, this stuff is super cheap and makes a super effective refractory clay for kilns. I make a 50/50 mix of this and plaster of Paris.
I bought 25kg of plaster of Paris for £18 last year, shop around for a good price online. With it I have made two types of kilns and I still have about a third left.
One of my kilns is used for heat treatment and is fairly big, so the plaster of Paris really does go a long way. I have never had a problem with cracking etc I have read some people have.
Just be sure when you have made your kiln to heat it very very gently for a long time. Low and slow, I cannot stress this enough. If you are making a small one, a good idea is to heat it (cure it) in your cooker oven.
John Smith 16 years ago
It was based on this, but a little simpler. You'll need Perlite (availible in the gardening section, DON"T get vermiculite), silica sand (plain, clean sand, often sold as playbox sand), portland cement (sold in big bags at some hardware stores, outside. You will probably need help because an average bag weighs 90-something pounds), and bentonite (cheap kitty litter, oil absorbing clay, etc., it doesn't need to be powdered, although that would be better.).
Combine one part perlite, one part silica sand, and one part bentonite.
mix well and add a small amount of water, just enough to make it moist. let this sit for 30 minutes, mix again, add a little more water, and let it sit for 45 minutes. Now add one part portland cement, and mix more water in. You are looking for a moist/wet crumbly-ish texture. Grab some in your hand, and squeeze. If it holds well, then you're done. If it is too crumbly, add more water and test again. Remember, it is not supposed to be as wet as normal concrete, so don't add that much water.
This is like all concretes with portland cements, it hardens by a chemical reaction (hydration), so adding more water will not keep it soft forever, so mold extra into bricks or plinth blocks (they hold the crucible up in gas foundrys; look at the bottom of the page).
In order for it to turn out pretty, and work well, you need to ram the refractory. I used a small dowel. First, make your bottom layer, then center a pvc pipe in the can, standing up. This will form the interior space. Ram the material in layer, ramming 2 or 3 layers, and then compacting it hard, repeating until you're done.
I used a 2" pvc pipe, and left about 1/2 to 3/4" on each side( I was using a small coffee can). When I was done, I waited 5 minutes, then pulled out the pipe with pliers.
I forgot to say that you need to ram with the pipe (the one going to the propane) in when you ram the material so it will leave a hole. So do that.
I've found it to be an easy formula, although you need to start the torch on low and run it for about 15 minutes to drive off any moisture left from before, before you crank it up to operationg temps. This only needs to be done once.
Today I was able to melt some aluminum, using it vertically.My crucible was a small steel match holder that I- I mean my friend, actually broke. My only power source was a regular propane tank.I I might post pics if I get around to it. I poured it into a small ingot, using small channel iron (actually steel).
I'm thinking of making an instructable on the refractory, small forge, and a helium tank foundry. The foundry is the only one not completed.
Also, I found that when measuring out the materials, using a plastic cup is a good way of measuring. I each part is +3/4 of a plastic cup, then you'll have just enough to complete the forge (in my case). Don't cut it short!
I hope you appreciate this because it took me a long time to write this comment (I type slow).
redhawk44 12 years ago
Vermiculite is a superior product for making firebrick refreactory.
1010tbone 15 years ago
John Smith 15 years ago
The refractory mix is composed of Portland cement (1.5 parts), silica sand (2 parts), perlite (1.5 parts) and fireclay (2 parts). The first three components are mixed together thoroughly.
Thats the formula.
However, its not as great as i thought it was at the time, now that i have tried different refractoires(that post was about a year ago).
Also, portland cement is a flux at high temperatures. Most people say to skip the portland.
I use Kaowool now. Its cheap, and truly great for a small gas forge like this. You might want to look into it.
If not, see [www.backyardmetalcasting.com/forums] for more info, or comment back.
Vendigroth 16 years ago
lemonie 16 years ago
Vendigroth 17 years ago
ironsmiter 17 years ago
afcbasser 16 years ago
ironsmiter 16 years ago
acoleman3 12 years ago
this would make an excellent tempering forge for small/med knifes, punches, chisels and the like.
teslafan100 13 years ago
beavercleaver 15 years ago
