Introduction: How to Make an Acrylic Night Lamp
Let’s craft a laser engraving acrylic night lamp! The acrylic night lamp presents intricate layers that add a unique look to your room.
Read this post and have a pleasant laser engraving time!
Machine Used
Thunder Bolt 30W
Material Needed
3mm acrylic
Engraving
- Speed:1000mm/s
- Power:45%
- DPI:350
Cutting
- Speed:5mm/s
- Max Power:80%
- Min Power:10%
Step 1: Place Your Acrylic for Laser Engraving
Choose an acrylic on the laser honeycomb bed.
Before your work begins
- Verify the lens is clean or there's no problem in the laser.
- Make sure the exhaust fan is working well.
- Ensure the air assist is on.
Step 2: Open the Night Lamp File
mport the night lamp design in LightBurn and check if your acrylic size is large enough.
For laser engraving night lamp with a lot of elements, ensure there are no misalignments or unnecessary overlaps in the file. Double-check everything, and decide if you want to add or subtract elements according to your preferences.
Step 3: Check the Laser Night Lamp Settings
Ensure that the parameters are set correctly to achieve the ideal laser engraving night lamp.
If the min power is too low, it will cause the stroking corners will be too shallow and the cutting corners will not cut through; if the min power is too high, it will cause the stroking to cut through the corners and the laser cutting will be bad at the corners.
Step 4: Focus on the Acrylic
Without focusing, your outcomes may fall short of expectations. So before starting, make sure you’ve rightly focused.
For focusing, you have two options: Auto Focus, which is simple—just press the AF button on the Thunder Bolt screen. Then you’re ready to have a laser engraving.
Step 5: Frame the Night Lamp Design and Start Laser Engraving
When you click “Frame”, the red light will display the laser engraving area. This is a safe process, and the frame will align with the acrylic. Once aligned, simply press “Start” to begin the night lamp laser engraving with the Thunder Bolt!
Step 6: Monitor the Laser Engraving Process
To avoid any issues, carefully monitor the laser engraving, especially when unusual conditions like alarms arise.
Considering the laser cutting energy, for safety reasons, we advise against staring directly at the process, even with the laser door closed.
Step 7: Complete the Night Lamp Laser Task
When the laser engraving night lamp is completed, it’s time to get it out. Then it’s just a fun assembly time to get the ideal night lamp. Imagine the joy of assembling the night lamp, as each piece clicks into place to create a beautiful, layered home decoration.
Laser engraving night lamp is perfect for home, especially when you’re enjoying a family bonding moment. You can even have your private house laser engraving night lamp for a one-of-a-kind room style!
#LaserEngraving #PrecisionEngraving #FreeLaserFiles #LaserCrafting #DIYProjects #CraftTips #UniqueGifts #PersonalizedGifts #GiftIdeas #NightLampDesign #LampArtistry #OneOfAKindNightLamp #NightLampElegance
