Introduction: How to Make an Auto-Omni Vehicle
What can an Auto-Omni vehicle do?
The Auto-Omni vehicle is equipped with three omni wheels and it can automatically move to any directions, totally independent of human control, whether by a console or a mobile App.
Step 1: So What’s an Omni Wheel?
Omni wheels or poly wheels, similar to Mecanum wheels, are wheels with small discs around the circumference which are perpendicular to the turning direction. The effect is that the wheel can be driven with full force, but will also slide laterally with great ease. You can google it if you want to understand how it works and get the whole picture.
Step 2: How Did I Build It?
I used a FreaksBot control board to make the vehicle, because the control board was based on Arduino Mega2560 which was easy to drive encoder motors and to extend sensors including camera sensors, ultrasonic displacement sensors etc. You can also use the sensors to make a roving vehicle or automatic barrier vehicle, etc. But now I’ll only show you how to make a vehicle that can move automatically in any directions.
Well, let’s begin!
Step 3: What to Prepare?
Parts needed in this project: Chassis made of wood boardOmni wheel x3Shaft Connector x3Encoder motor x3motor supporter x3FreaksBot x1Encoder motor wire x 3RC battery x1Screw setsPliersScrewdrivers
Step 4: Step 1: Make One Chassis First
The first thing to do is to cut a piece of wood board. We can use a laser cutter to do the job. Then we make holes on this board. Next we fix 3 motor supporters on the chassis. It’s no pickle for any of us.
Step 5: Step 2: Install Encoder Motors and Wires
No need to explain this step. You just have to make sure they’re installed properly and firmly.
Step 6: Step 3: Install Omni Wheels and Shaft Connectors
Step 7: Step 4: Install Omni Wheels on the Motors
It’s coming along! Look! You don’t see triangular vehicle every day in your life, do you? It’s starting to look cool!
Step 8: Step 5: Install FreaksBot and the Battery
Connect all connectors and the vehicle is now completely installed. As the FreaksBot board integrates motor driver IC, we do not have to go through a complex wiring.
Step 9: Step 6: Upload Codes to FreaksBot
Assume that your computer has installed Arduino IDE. You can download the full codes on our wiki later on, decompress and copy the codes to the libraries folder in the Arduino IDE installation directory. Now we’re all set. We just need to follow below steps to upload codes to FreaksBot.
#1 Connect FreaksBot to computer
#2 Open Arduino IDE
#3 Choose Examples file ‘EF_OmniCar’
#4 Set up board:”Arduino/Genuino Mega or Mega 2560”
#5 Set up Process:”Atmega2560 (Mega 2560)”
#6 Choose the right port
#7Click the upload button till the upload is completed.
Now the Auto-Omni vehicle is completed. Turn it on to feel the charm of your masterpiece! You can also use the App to control the Auto-Omni vehicle.
