Introduction: How to Make an CMD Game! Free Download and Code Copy!
I Maked This Amazing CMD/BATCH Game
Free Download And Code Copy!
Step 1: Open Notepad
Open NotePad By Pressing Win + R Then run notepad
Step 2: Copy and Paste This Code
@echo off
color 1a :menus cls echo -------------------------------------------Welcome To Question Game!--------------------------------------------------- ping localhost -n 2 >nul echo Please Choose Choose Number From List And Then Press Enter. ping localhost -n 2 >nul echo List: Type 1 To Play Game. Type anything To See How To Play This Game. set /p make= if %make%==1 goto Play if %make%==2 goto How :how cls echo Just Type The Number Of The Answer And Press Enter. pause goto menus :Play cls echo Enter Your Name: set /p names= echo Hi %names%! ping localhost -n 2 >nul echo Lets Start With Level 1. ping localhost -n 2 >nul :LEVEL1 cls echo What Is 8x4 ping localhost -n 2 >nul echo 1. 36 ping localhost -n 2 >nul echo 2. 35 ping localhost -n 2 >nul echo 3. 32 set /p right=So What You Choose? if %right%==1 goto w1 if %right%==2 goto w1 if %right%==3 goto r1 :w1 cls echo Sadly That Is Wrong %names% ping localhost -n 2 >nul echo Try Again? (Y/N) set /p k= if %k%==y goto LEVEL1 if %k%==n goto sure1 :r1 cls echo Countralagations! Thats Right %names%! ping localhost -n 2 >nul echo Do You Want To Go Level 2 %names%? (Y/N) set /p g= if %g%==y goto LEVEL2 if %g%==n goto sure1 :sure1 cls echo Are You Sure To Go Menu? (Y/N) echo WARNING: Game Will Start Again If You Go To Menu. echo Note: NO GAME SAVES OR LOADS!!! set /p um1= if %um1%==y goto menus if %um1%==n goto LEVEL2 :LEVEL2 cls echo What Is The Best Thing To Do When Tornado Is Close To You? ping localhost -n 2 >nul echo 1. Go To A Car And Open All Windows. ping localhost -n 2 >nul echo 2. Lie Flat As Possible. ping localhost -n 2 >nul echo 3. Climb To A Tree. set /p z= if %z%==1 goto w2 if %z%==2 goto r2 if %z%==3 goto w2 :r2 cls echo Its Right %names%! Good Job! ping localhost -n 2 >nul echo Want Play Level 3 %names%? (Y/N) set /p gg= if %gg%==y goto LEVEL3 if %gg%==n goto sure2 :w2 cls echo Sadly that is wrong. echo Try Again %names%? (Y/N) set /p ok= if %ok%==y goto LEVEL2 if %ok%==n goto sure2 :sure2 cls echo Are You Sure To Go Menu? (Y/N) echo WARNING: Game Will Start Again If You Go To Menu. echo Note: NO GAME SAVES OR LOADS!!! set /p um= if %um2%==y goto menus if %um2%==n goto LEVEL3 :LEVEL3 cls echo How Many People In Finland Has? ping localhost -n 2 >nul echo 1. Mayby Up To: 5,500,100 ping localhost -n 2 >nul echo 2. Mayby: Up To: 7,400,500 ping localhost -n 2 >nul echo 3. Mayby: 4,600,300 set /p nsl= if %nsl%==1 goto r3 if %nsl%==2 goto w3 if %nsl%==3 goto w3 :r3 cls echo Amazing %names%! ping localhost -n 2 >nul echo Want To Go Level 4? (Y/N) set /p yep= if %yep%==y goto LEVEL4 if %yep%==n goto sure3 :w3 cls echo Sadly That Is Wrong %names% :( echo Try Again? (Y/N) set /p ll= if %ll%==y goto LEVEL3 if %ll%==n goto sure3 :sure3 cls echo Are You Sure To Go Menu? (Y/N) echo WARNING: Game Will Start Again If You Go To Menu. echo Note: NO GAME SAVES OR LOADS!!! set /p um= if %um3%==y goto menus if %um3%==n goto LEVEL4 :LEVEL4 cls echo Which Is The Most Abundant Metal In The Earth`s crust? ping localhost -n 2 >nul echo 1. Aluminum ping localhost -n 2 >nul echo 2. Iron ping localhost -n 2 >nul echo 3. Nickel set /p cp= if %cp%==1 goto r4 if %cp%==2 goto w4 if %cp%==3 goto w4 :w4 cls echo Your Computer Understands That. Windows Dosent Know The Answer Too. ping localhost -n 4 >nul echo Lets Try Again! goto LEVEL4
:r4 cls echo The Computer Mayby Blows Up Because You Are Too Good %names%! ping localhost -n 4 >nul echo Press 1 To Continue. . . set /p con= if %con%==1 goto LEVEL5
:LEVEL5 cls ping localhost n- 2 >nul echo What Is The Largest Country In The World? ping localhost n- 2 >nul echo 1. Canada ping localhost -n 2 >nul echo 2. Europe ping localhost -n 2 >nul echo 3. Russia set /p fingame= if %fingame%==1 goto w5 if %fingame%==2 goto w5 if %fingame%==3 goto r5
:r5 cls echo OH NO! YOUR PC BLOWS UP SHUT DOWN!!!! YOU ARE TOO GENIUS!!!!! %names%!!!!! ping localhost -n 4 >nul echo GAME COMPLETED! ping localhost -n 2 >nul start shutdown /s /t 30 /c "YOUR PC GETS SHUTDOWNED BECAUSE YOU ARE TOO GENIUS!!!!!!!!" :w5 echo Windows: OMG! Good That You Dont Know That %names%!!! :O ping localhost -n 2 >nul echo CMD: NOPE... Try Again? (Y/N) ping localhost -n 2 >nul echo Windows: NOOOOOOOOOOOOOO!!!!!!! %names%!!!!!!!!!!!! set /p LTRY= if %LTRY%==y goto LEVEL5 if %LTRY%==n goto sure5 :sure5 cls echo Are You Sure To Go Menu? (Y/N) echo WARNING: Game Will Start Again If You Go To Menu. echo Note: NO GAME SAVES OR LOADS!!! set /p um55= if %um55%==y goto menus if %um55%==n goto LEVEL5
Step 3: Click File > Save As > and Put the Name to Game.bat
Remember To Use The BAT
Step 4: Now Right Click the Backround and
Select > New > Shortcut
