Introduction: How to Make an Easter Egg Basket
About: Laser professor
Let’s craft a laser-cut wooden Easter egg basket! This beautifully designed decorative piece adds a festive touch to your Easter celebrations with intricate details and a charming wooden finish.
Ready to give your projects the creative edge they deserve? Read this post and enjoy a joyful laser-cutting experience!
Machine Used
Thunder Bolt 30W
Material Needed
3mm plywood
Cutting
  1. Speed:15mm/s
  2. Max Power:45%
  3. Min Power:10%
Step 1: Place Your Plywood for Laser Cutting
Before your work begins
  1. Verify the lens is clean or there's no problem in the laser.
  2. Make sure the exhaust fan is working well.
  3. Ensure the air assist is on.
Choose a flat plywood board on the laser honeycomb bed.
laser cutting easter egg basket material
Step 2: Open the Basket File and Check the Laser Plywood Settings
Check out the design is important. Since there are a lot of parts, don’t miss anyone! And ensure that the parameters are set correctly to achieve the ideal laser cutting Easter egg basket. In addition, laser compensation is to be set.
If the min power is too low, it will cause the stroking corners will be too shallow and the cutting corners will not cut through; if the min power is too high, it will cause the stroking to cut through the corners and the laser cutting will be bad at the corners.
laser cutting easter egg basket setting
Step 3: Focus on the Plywood
Without focusing, your outcomes may fall short of expectations. So before starting, make sure you’ve rightly focused.
For focusing, you have two options: Auto Focus, which is simple—just press the AF button on the Thunder Bolt screen. Then you’re ready to have a laser cutting.
auto focus
Step 4: Frame the Easter Egg Basket Design and Start Laser Cutting
When you click “Frame”, the red light will display the laser cutting area. This is a safe process, and the frame will align with the plywood. Once aligned, simply press “Start” to begin the plywood laser cutting with the Thunder Bolt!
laser world map 3
Step 5: Monitor the Laser Cutting Process
To avoid any issues, carefully monitor the laser cutting, especially when unusual conditions like alarms arise.
Considering the laser cutting energy, for safety reasons, we advise against staring directly at the process, even with the laser door closed.
Step 6: Assemble the Easter Egg Basket
When the laser cutting plywood is completed, it’s time to get it out. Then it’s just a fun assembly time to get the ideal Easter egg basket. Imagine the joy of assembling the basket, as each piece clicks into place to create a beautiful Ester decoration.
Come and Try!
Laser cutting on wooden Easter egg baskets adds a unique, festive touch while showcasing intricate craftsmanship and durability. Whether you’re decorating for an Easter gathering, creating a seasonal centerpiece, or crafting a special keepsake, laser cutting offers a stylish and charming way to celebrate the holiday with creativity!
laser cutting easter egg basket assemble
laser cutting easter egg basket show
