Introduction: How to Make an Easter Mug
About: Laser professor
Let’s make your Easter celebration as creative and joyful as you are! Laser etching adds intricate designs or personalized style onto vibrant green ceramic mugs, making them perfect for parties, gifts, or special keepsakes.
Ready to laser something special this Easter? Follow the steps below and etch your way to a holiday full of charm and creativity!
Machine Used
Aurora Lite 50W
Material Needed
Green Ceramic Mugs
  1. Laser Etching
  2. Speed: 1000mm/s
  3. Marking Power: 60%
  4. Frequency: 50kHz
  5. Line interval: 0.02
Step 1: Clamp the Ceramic Mug
Check out!
  1. The machine is connected and operating normally, and the lens cover has been removed.
The mug are cylindrical so we need a rotary to have a laser etching.
First, prepare the adapted rotary.
rotary accessory
Next, attach the rotary to the machine.
connecting the rotary
Finally, clamp the mug to the rotary. Don’t forget to check to make sure it’s clamped steady and level. It’s important for laser etching.
Easter mug clamped to rotary accessory
Step 2: Import Laser Etching Easter File and Check Out
oad your design into LightBurn software, adjusting its size and position to fit your ceramic mugs. Then make sure the laser etching parameters are set correctly. And the parameters of the rotary axis should also be set appropriately.
laser etching Easter mug setting
rotary setting
Step 3: Don't Miss the Focus
Missing the focus is one of the biggest reasons for laser etching failure. So don’t forget to click the AF button for auto focus. Of course, manual focus is also effective.
Of course, manual focus is also effective. Hang the focal stick at the correct position under the lens, and then carefully adjust the Z-axis height. When the end of the focal stick just touches the surface of the mug, it is in focus!
Red light focus
Auto focus
focus ruler focus
Manual focus
Step 4: Ready to Start Laser Etching
Press the frame button and check if the visual red light indicate the right area to be etched. The frame should be located in the middle of the mug. If not, move the pattern positions until they align.
After checking, close the laser door and begin Aurora Lite’s operation.
framing and start
Step 5: Monitor the Laser Etching of Ceramic Mug
Stay near the machine throughout operation to monitor for any unusual sounds or alarms. This vigilance ensures safety during laser etching, as laser energy is potent. Avoid looking directly at the laser beam, even with protective measures in place.
Step 6: Complete the Task
Once laser etching is complete, carefully open the door and get your newly personalized ceramic mug. Laser etching does not produce toxic substances, and you can use the ceramic mug after a simple cleaning!
washing Easter mug
Come and Try!
Laser etching on vibrant green ceramic mugs adds a unique, festive touch while ensuring safety and durability. Whether you’re creating personalized mugs for an Easter party, a themed event, or a special keepsake, laser etching offers a stylish and lasting way to celebrate the occasion with charm and creativity!
laser etching Easter mug done
