Introduction: How to Make an Easy 4 Step Puzzle Box (Out of a Log)
Puzzle boxes are tricky, as they come in the name, but this one is simple, we promise!
Disclaimer: This post contains affiliate links.
Step 1: Tools/Materials
1 Log
Wood Glue: https://amzn.to/2SJXzSj
1 Foot Quick Grip Clamps: https://amzn.to/2VO2W54
Natural Wood Stain: https://amzn.to/2VO2W54
Table Saw: https://amzn.to/2VO2W54
Combination Square: https://amzn.to/2VO2W54
Planer: https://amzn.to/2VO2W54
Jointer: https://amzn.to/2VO2W54
Dato Blades: https://amzn.to/2VO2W54
Chop Saw: https://amzn.to/2VO2W54
Nailer: https://amzn.to/2VO2W54
Drill: https://amzn.to/2VO2W54
Bandsaw: https://amzn.to/2VO2W54
Belt Sander: https://amzn.to/2VO2W54
Tape Measure: https://amzn.to/2VO2W54
Bible (not an affiliate link): https://amzn.to/2VO2W54
For those of you who love learning new subjects just like us, I would highly recommend checking out the online learning program: Masterclass http://shrsl.com/1irvo as they have EXTREMELY helpful tutorials on almost every subject under the sun. I took their Stephen Curry Basketball class and it was amazing! They have a couple of other classes that I want to check out as well including their class on Game Design http://shrsl.com/1irvo Maybe it will help us design some more puzzles!
Step 2: Log Milling
Now personally, we wouldn't recommend making any puzzle box out of a log mainly because they're extremely hard to get straight. But if you do choose to make yours out of a round log, you will need to at least have a planer and a table saw to get your ripped pieces cut down to size.
Step 3: Main Box Construction
The overall construction of the main box was fairly standard. However, the two things that you will have to do before you nail and glue everything together. The first is that you will need to make some dadoes along the long edges of your box so that you can slide in the two locking panels that you will be making in a moment. The other is that you will need to keep one end of your box detached from the rest of your box. The reason for this is because that end piece will need to be cut into two separate pieces so that you can hide one of the locking mechanisms of your box.
Step 4: Panel Locks
These next two panel locks are quite complicated which is why I think it would be best to watch the video at the top of this instructable so that you fully understand how they work.
Step 5: The Actual Steps
Technically you could call this puzzle box a 5-step puzzle but really it is only 4. The way that this box is opened is by twisting the knob on the right so that the peg below the panel can be lined up with the pre-drilled hole. Once the peg is lined up, you can then pull on the knob so that it lifts the panel up entirely. After this step, the second panel can then be slid backwards toward the first panel so that you can remove the end piece and access the box.
