How to Make an Easy to Use Tape Dispenser
Intro: How to Make an Easy to Use Tape Dispenser
If you ever need to wrap a package or box for mailing or make a box for a special project, you need to have tape handy. Especially helpful when wrapping gifts at Christmas time or other holidays. I came up with this idea to be able to use only one hand, tear off what I needed and hold the project with the other hand. Tape is easily added or removed, and the whole thing is easily stored as it is held in place by a c-clamp or other clamp of choice.
STEP 1: Parts You Need to Make This
There are 5 pieces of wood used in this project. I cut down a two by four that I salavaged.
1. Base: 3/4 inch pine, 7 1/4 x 11 inches.
2. Two uprights: pieces of 2x4; 2.5x2.5x1.5inches.
3. One crossbar: 2 1/2 x 10 x 1 1/2inch.
4. Tape cutting mount, 2 1/2 x 6 1/4 x 1 1/2inch.
Total= 5 pieces
Two bolts with nuts are needed: 5/16 x4 1/2 bolts with nuts and 2 washers each.
One piece of hacksaw blade, cut or broken to fit the tape cutting mount.
Total= 5 pieces
STEP 2: Drill Holes in Wood Pieces
The holes are drilled in the two uprights to hold the crossbar with tape in place. Drill the crossbar, uprights and base at the same time so that there is no alignment problem later on. Using a long 3/8 inch bit does the trick.
Also, drill three holes in the hack saw blade to be able to attach it to the cutting block. (Use a 3/32 in bit for these short screws). Three holes are drilled in the botton of the base and into the cutter mounting block. Use a 1/8 inch bit for this step.
STEP 3: Attach Hacksaw Blade to Cutting Block
Self explanatory, see picture and image notes.
STEP 4: Add Your Tape to Crossarm
Choose the tape you want for whatever job you are doing. I make boxes and wrap them sometimes, so have used the tape shown.
STEP 5: To Use, Clamp Dispenser to Your Work Bench or Table.
When clamped in position, only one hand is needed to pull of the tape you need while holding your project with your other hand. When done, dispenser can be removed and stored out of the way.
35 Comments
mkambas 10 years ago
some time ago i recycled a wooden toilet-paper roll holder after our bathroom was renovated. but now i've switched to a longer paper towel holder for all kinds of tapes. reused the serrated long blade from a plastic wrap dispenser i had saved once, before discarding the empty box!
badpanda 12 years ago
WonderWidget 13 years ago
But, I think now I'll have to make one like yours for tape rolls, too! This one will have the cutting mount, tho. I may pick up a couple cheap TP rollers for starters, and maybe mount the arms farther apart, then use a trimmed down spring tension curtain rod instead of the usual rollers. I have to say I like the idea of using PVC pipe, since tape rolls have the larger holes. Two holes could be drilled at each end opposite each other and long screws added atop the 2 supports, sticking up. The pipe could then be easily slid on and off over the screws. Cut off the screw heads, and a wingnut could be added to secure the pipe as well. Big thanks for sharing your idea. Works for me!
Creativeman 13 years ago
WouldWorkShop 13 years ago
pudi.dk 14 years ago
I use a piece of PP pipe that fits the inner rings of the tape. A wooden plug in each end, each rolling on a bended piece of stainless steel plate that I found.
Only downside I can think about is that hacksaw blades are only sharp in one direction, to allow cutting when the hacksaw it pulled forward on an object. This would mean that you're limited to pinching the tape on an angle to get it off.
jamwaffles 14 years ago
My friend has a saying that goes with the two tools in his mountain-biker's toolkit: if it moves when it shouldnt, use duct tape but if it doesnt move when it should, use WD-40. Maybe someone could make a gun that combines the two and instantyl fixes anything?
James
dontno 14 years ago
xenomachina 15 years ago
Creativeman 15 years ago
Da_Fudge 15 years ago
Bright Shadow 15 years ago
Thornburg 15 years ago
Chico 15 years ago
