Introduction: Elegant Ring Pillow
This is a relatively easy item to make. I love it because it's so easy to match your wedding colors perfectly.
Step 1: Materials Needed
- White Satin
- Satin to match your Wedding Colors (I chose Platinum)
- Batting or Polyester Filling
- Sewing Machine
- Pins
- Scissors
- Needle
- Thread
- Pretty Button/Brooch for Center
- Ribbon (30" long)
- Iron
- Sewing Machine
- Pins
- Scissors
- Needle
- Thread
- Ribbon (30" long)
- Iron
Step 2: Cut Fabric
Cut two 7.5" squares of your white satin, and two 7.5" squares of your colored satin.
Step 3: Prepare the Center Band
Fold the center band right sides together, lengthwise.
Pin.
Pin.
Step 4: Sew and Iron the Band
Sew using a 1/4" seam allowance.
Iron the seam flat to one side.
Step 5: Flip the Band Right Side Out
Flip the band right side out, with the seam in the center of the band, as shown.
Step 6: Baste the Band Edges Together
Baste the edges together, using a 1/4" seam allowance.
Step 7: Sew the Bands to the Center of the White Pieces
Sew the right side of each band onto the right side of each white piece, along the sides, using a 1/4" seam allowance.
Step 8: Sew It All Together!
Step 9: Flip Pillow Right Side Out
Flip the pillow right side out through the opening.
Step 10: Stuff the Pillow
Fill the pillow with stuffing or with multiple 6" squares of batting.
Pin the opening, and hand-stitch it shut.
Using a safety pin, pin the center band together in the middle.
Step 11: Sew on the Button and Ribbon
Take some thread and tie a knot around the center of each band (where the safety pin is) to keep it in place for when you sew on the button/brooch.
Sew on the button/brooch.
Tie your ribbon around the button/brooch, and stitch it in place to secure it.
Step 12: Tie the Rings Onto the Ribbon
Tie the rings onto the ribbon, and you're ready to get married!
You can choose to use real rings or fake rings, depending on how much you trust your ring bearer. ;)
