Introduction: How to Make an IR Remote Tester
IR Remote Tester is simple circuit that can be a good tool to check whether a remote hand set is working or not. It uses the commonly available IR sensor TSOP 1738.The IR sensor has a PIN photodiode and an FET signal amplifier enclosed in an Epoxy case.
For more projects subscribe my youtube channel [ Subscribe ]
Now I am going to instruct how to make an IR Remote Tester with less number of components.
Lets Get Started..
Step 1: Components Required
Step 2: Circuit Construction
Connect IC 7805 Ground,Output pins to GND, Vs of Tsop1738 respectively.
Connect a 100 Ohm resistor from Vs pin of tsop1738 to +ve pin of LED and -ve pin of LED to output of tsop1738.
Connect 9V battery +ve to Input pin of IC7805 and -ve of battery to GND of 7805
Circuit Construction Completed ..
When you press any button of IR remote , the LED in the circuit blinks.
Datasheets of IC7805 , TSOP 1738 is attached.
Step 3: Construction and Testing
Feel free to comment.
For more projects subscribe my youtube channel [Click Here]
