Introduction: How to Make (and Dye for Easter) Easy-to-peel Boiled Eggs
Using this simple method to boil eggs, they should come out perfect and easy to peel every time.
Step 1:
Add 1 tbsp of baking soda to a pot of water and bring to a boil.
Step 2: Add the Eggs
Add the eggs after the water has started boiling and continue to boil for 11 minutes.
Step 3:
The eggs come out very easy to peel. The whites aren't rubbery and the yolks are a bright yellow.
Now, unless you are dying them for Easter....or just want to have pretty colored eggs year round for no reason, that's all there is to this instructable.
If you do want to see a few ways to dye the eggs, stick around for the rest of the steps.
Step 4: Making the Solution
Add 1 tbsp of white vinegar to a 1/2 c of warm water.
Step 5: Colors
In each cup, add 20 drops of food coloring. You can always mix two colors to get an unique hue (for example, mix 12 blue drops and 8 red drops, or 14 yellow and 6 red). Stir the mixture before adding your eggs.
Step 6: Time to Dye!
Place your eggs in the dye and leave for 5 minutes.
Step 7: Done!
You should be able to get a wide variety of colors using this method and experimenting with the different ratios of drops.
If you want something more than just regular dyed eggs, there's still two more ways to dye the eggs.
Step 8: Vinegar Solution
Mix 1 tsp white vinegar to 1 c warm water, pour solution in a spray bottle.
Step 9: Wrap the Egg
Wrap your egg in a paper towel and secure the ends with a tiny rubber band.
Step 10: Color It!
Add drops of food coloring directly on the wrapped egg. Try to not leave too many white spaces.
Step 11: Spray the Egg
Spray the egg all over with the vinegar & water solution and let sit for 5 minutes.
Step 12: Unwrap
Remove the rubber band and take the egg from the paper towel.
Step 13: Done!
Each egg that you do this to will look unique and they all come out gorgeous.
If you still want to know one other way to dye the eggs and were paying attention in step 7, you will know to stick around for the last method.
Step 14: Grab That Toothbrush
Using an egg that has been dyed using the first method, put a couple of drops of food coloring on a tooth brush.
Step 15: Now for the Fun Part
Using your finger, flick the dye onto the egg. I do recommend even if you don't wear gloves for method one or two, break them out for this method.
Step 16: Voilà
I love the way these turn out and it's very simple to do.
Step 17: How Are You Going to Dye Your Eggs?
Let me know how you are going to dye your eggs for tomorrow!
